Favorites on display
I just came back from a trip to Detroit to the car show. I used the nav several times.
Problem is that now my radio favorites no longer display on the screen. Using the left steering wheel switches to cycle through them is tedious. I went into setup and ensured that it was set to display five. No change. Then I set it to display ten. Still nothing. Back to my desired five setting.
If I press the home button I get the expected option screen, with the small arrow at the bottom right, which will bring up the favorites. That would be especially clumsy to make a selection.
Ideas?
Dave
Ideas?
Dave
Moderator
Go to the Audio (Radio) screen and put your finger at the bottom of the screen and drag it up. It may take you a few tries, but this IS the answer. At some point you dragged them down and you may not have realized you did it.
Dave
