GS Vents top rear fender
Old 09-15-2016, 03:30 PM
navyvetteran
navyvetteran's Avatar
Default GS Vents top rear fender
What are the GS top rear fender vents for, the lower vents are brake for cooling
Old 09-15-2016, 03:35 PM
rmorin1249
rmorin1249's Avatar
Received 1,738 Likes on 1,174 Posts
St. Jude Donor '15-'16,'18
Tranny cooling, I think just like the Stingray. Not present on the verts.
Old 09-15-2016, 03:57 PM
djnice
djnice's Avatar
In the rear fender there is a tranny cooler on one side and a diff cooler on the other. I think that's the case on all C7's, but the Z06 and GS are supposed to be larger coolers. The air routes in the top and out the rear.
Old 09-15-2016, 06:08 PM
2K14C7
Support Corvetteforum!
2K14C7's Avatar
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
You need the Z51 package to get a functional diff cooler.
Old 09-15-2016, 06:31 PM
Larry/car
Larry/car's Avatar
More of a cosmetic thing. As previously mentioned the convertible doesn't have the quarter panel vents.
Old 09-15-2016, 06:35 PM
2K14C7
2K14C7's Avatar
More than cosmetic. They work very well. They couldn't use the same location on the convertibles due to interference from the top mechanism.
They relocated the intakes under the car.
dvilin (09-15-2016)
Old 09-15-2016, 08:07 PM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
Definitely NOT. On convertibles the air is brought in through intakes that are located on the underside of the car.
Old 09-15-2016, 08:20 PM
sTz
sTz's Avatar
Received 2,423 Likes on 1,597 Posts
As mentioned, one is for the differential cooling (Z51 and Z06), and the other is for transmission cooling.
itaylorm (09-15-2016)
Old 09-15-2016, 10:06 PM
dmhines
dmhines's Avatar
Actually convertibles have vent in rear wheel well.
To GS Vents top rear fender
Quick Reply: GS Vents top rear fender
