The new Super Sport A/S 3+
Old 10-19-2016, 12:05 PM
Jaykoh-Z51
Jaykoh-Z51's Avatar
Default The new Super Sport A/S 3+
what's the difference between the two different load rating AS3+ tires for the Z51
was at Kauffman tire. There were two different ones same size. Different cost.
Old 10-19-2016, 07:46 PM
Jay_Davis
Jay_Davis's Avatar
There shouldn't be.
Do you know what the load rating was?
Old 10-20-2016, 12:09 AM
Dif
Support Corvetteforum!
Dif's Avatar
Did you check if one was a Run Flat = more $$ ?
Possible one was the new AS3+ Z ....
Old 10-20-2016, 09:37 AM
Jaykoh-Z51
Jaykoh-Z51's Avatar
They are both the 3+ ZP (run flats).
So whch speed rating should we get get for the Z51?
Old 10-20-2016, 11:09 AM
c8nukeZ51
c8nukeZ51's Avatar
Tirerack.com shows two different speed ratings ( W or Y )
according to there tech page, W is good up to 168mph and Y is good to 186mph
but they're not showing two different prices or not showing which you are getting.
$222 each for the fronts and $292 each for the rears (both with a free Road Hazard Protection plan)
Old 10-20-2016, 11:52 AM
Dif
Dif's Avatar
I know they can be ordered, but So far I have not seen any AS3+ Run Flats on any tire websites I searched
Only the AS3 and the AS3+ ...
Old 10-20-2016, 11:54 AM
Jaykoh-Z51
Jaykoh-Z51's Avatar
The guys made a mock order sheet so I could see the installed price. I'll look and see. But they said they had them at the warehouse. This is just west of Atlanta.
Dif (10-20-2016)
Old 10-20-2016, 12:13 PM
c8nukeZ51
c8nukeZ51's Avatar
You're right,,,looking back at tirerack they only show non-runflats
Old 10-20-2016, 12:37 PM
0Luke@tirerack
Former Vendor
Luke@tirerack's Avatar
St. Jude Donor '11-'12
they are not on the website yet ... but, if you would like to order them call me directly
800-428-8355 ext. 4362
Old 10-20-2016, 12:59 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Originally Posted by Stangslayer
Different speed ratings89 vs 95
The numbers you posted are not speed ratings, but are the load capacity of the tire.
89 = 1279 lbs
95 = 1521 lbs.
Speed ratings are not represented by numbers.
Old 10-20-2016, 01:26 PM
Jaykoh-Z51
Jaykoh-Z51's Avatar
So...pardon my ignorance here. Which ones will be best then?
Old 10-20-2016, 07:17 PM
Jay_Davis
Jay_Davis's Avatar
Still doesn't make sense that there would be 2 exact tires, just with different load ratings. Try to find more specific information on a label.
They will also be different front to back, so I don't know which we are talking about.
The original PSS ZP on from the factory is 89Y in the front and 95Y in the rear. I would go no lower than that.
Old 10-21-2016, 09:28 AM
JoesC5
JoesC5's Avatar
Are you sure that they are not (89Y) and (95Y) instead of 89Y and 95Y?
There is a difference.
Old 10-21-2016, 09:44 AM
QKSLVRZ
QKSLVRZ's Avatar
If they are exactly the same (even compound), it could be to allow some sidewall stiffness tuning/selection. If they are mostly competition /sports car tires, or standard equipment, that too could cause the manufacturer to ask for a different stiffness for tuning the cars performance.
Old 10-21-2016, 02:54 PM
JoesC5
JoesC5's Avatar
Or the rear tire's load capacity could be higher because if you load the car with it's maximum cargo carrying capacity of around 600 pounds, that additional weight would be on the rear tires.
Difficult to add that additional weight over the front tires, thus the front tires do not have to have as much load capacity as the rear's when the car is fully loaded with people and luggage.
Old 10-21-2016, 03:11 PM
HoustonMidtown
HoustonMidtown's Avatar
Luke,
Do you offer us better pricing than what I would see on your website ? I need to buy a set of replacement front tires.
Old 10-21-2016, 04:05 PM
0Luke@tirerack
Former Vendor
Our website pricing is set at the best price we can offer. We don't ask our customers to remember special codes or jump through hoops to prove membership in order to get the best price available from us at the time.
We support the members of this forum through our sponsorship with both direct financial support to the forum owners and the technical information and advice I hope the members find helpful.
Please remember, that when ordering use one of our banner ads or the supplied discussion links (i.e. http://www.tirerack.com/a.jsp?a=CN3&url=index.jsp). When you order that way you are identified as a forum member and a portion of the proceeds will go to support the Corvette Forum site.
Also, If you order online, please reference "Luke" on the order as a previous contact.
HoustonMidtown (10-21-2016)
To The new Super Sport A/S 3+
Old 10-21-2016, 06:24 PM
Jay_Davis
Jay_Davis's Avatar
Yes, technically it's (89Y) and (95Y) but that only affects the speed rating. The important numbers in this case are the 89 and 95 since I'm guessing top speed rating isn't going to be critical for an all-season tire.
Old 10-23-2016, 05:52 PM
Thunder22
Thunder22's Avatar
Received 2,312 Likes on 1,457 Posts
Do you not answer PM's?
Old 10-25-2016, 02:17 PM
QKSLVRZ
QKSLVRZ's Avatar
Then the sidewall would likely be stiffer in the rear.
Quick Reply: The new Super Sport A/S 3+
