Front camera activation
I suppose I could be reading my owner's manual but it's much more fun to be on this forum. My front cameras don't come on automatically all the time. I was under the impression that anytime you were moving forward below 5 mph the front cameras were active. This is not the case my GS M7. Is there a setting I need to change.
It only comes on automatically when going from R to 1. I do use it almost everytime I pull into a parking spot or when pulling into my garage. I just hit the little video icon when going under 5 and it turns it on, but it has to be done manually.
The following 3 users liked this post by PeteC7:
My 2015 does not have the front camera. I would like to have it to assist pulling into parking spaces to avoid touching a high curb. Sounds like the option must be turned on to work unless you are shifting forward from backing. Front camera should come on when forward speed is 5 mph or less.
DWS44 (08-27-2018)
Yes this is the reason. It would be annoying to have the camera's flip on and off all the time in slow traffic.
Though would be cool if it had a sensor on it that identifies protruding objects under 8" tall from the ground like curbs, speed humps, etc.
That does make sense. Would be nice if there was dedicated button on the dash for it.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
Just a suggestion...
Elmer
Carvin (08-25-2018)
blkvet6 (08-27-2018)
You can change the icons on your home screen to have it located easily there. Like say take off the weather icon, and add the park assist camera icon instead.
In Michigan the weather app isn't reliable anyway!
I have three GM vehicles all with the latest Infotainment system and didnt know you could move icons around. Great info thanks.
It's set to come on R to 1 so when you're parallel parking, front view comes on automatically. Back in with the rear camera on, then pull forward with the front view. Simple.
Corvette Enthusiast
I have the camera button on my "taskbar" (the buttons always on top), so I can hit it when I pull into parking spots.
BTW, it's only active under 8 kph (5 MPH).
Carvin (08-25-2018)
