Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake How-Tos
- How to Remove/Replace Front Brake Pads
Step by step instructions for do-it-yourselfers.
C7 Brake Pad Installation
"#1, Front bolts carry threadlocker 88861418 and are torqued to 162 ft lbs. The old thread locker must be completely cleaned off using denatured alcohol. This is both the holes AND the bolts. Now, after that time, the thread locker is applied to the threads and ALLOWED TO CURE FOR 10 MINS PRIOR to installing into holes and torqued to specification.
#2, REAR caliper bolts have no such requirements and are torqued to 89 ft lbs .
Both front and rear brake hose banjo bolts are torqued to 30 ft lbs using new sealing washers. No Loctite is used.
Calipers are installed DRY, THEN once torqued, pads are lubricated with 19303310 grease and installed with pins. There are no requirements to replace pad retainment pins or shims UNLESS there is corrosion or wear seen.
Bleeding of the braking system utilizes right rear, left rear, right front left front bleeding sequence and bleeder screws are torqued to 89 in lbs."
This information is from a "GM World Class Certified Service Technician" whose judgment and knowledge I trust.
It sure will be nice when the Service Manuals are available to owners.
Rich
The fronts can be done without taking the calipers off, I finally put the Carbotechs on tonight. If you simultaneously pry from the top and the bottom at the same time using 2 screwdrivers and a rag between them and the caliper, they will come out. Just grab the adhesive tape that is left behind with needle nose and you are good.
Blaine,
I just put a rag underneath the screwdrivers and I did not scratch the caliper at all, you do not have to pry hard. You just have to put even pressure on the top and bottom to get them out, as the pad has to come out evenly. If you have a heat gun/hair dryer you can use that to heat up the tape a little bit which might make it a little easier.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
Are you sure of that 175 lb ft? I show for the C6 175 N-m or 125 lb ft.
That is one hell of a lot of torque for that bolt.
Elmer
Elmer
Received 19,305 Likes
'20-'21-'22-'23-'24
Great information. Saved this for future reference.
Where are you finding the stock brembo pads for Z51?
every site i see says ACDelco and for all stingrays..
I track the car so want a good pads which the z51 seems to work fine.. and i dont want noise on the street..
I ran Carbotech 1521's in my last vette and put them in the C7 a couple weeks ago. MUCH less dust than the stock Z51 pads and what little dust there is is pale grey. Clean the rotor with brake cleaner to get as much of the old compound off the rotor surface. Drop the 1521's in and bed them well. They may sqeal a lilttle until you transfer some of the new compound to the rotor. Bedding takes care of that. For street use - even pretty highly spirited mountain road - I notice no downside to these pads. Sure is nice not having the wheels look like $hit 50 miles after you cleaned them.
I need a pad to hold up to track duty though the stock z51 one has been doing pretty good though i have been being easy on it/..
Supporting Vendor
St. Jude Donor '11,'13
Yes, 1521 is not a track pad but, we do make other compounds. As with any track pad you will have some noise and dust I know that's not what your looking for but if you change your mind I will be happy to help. All Carbotech compounds are compatiable with each other so you could swap pad for street and track with no issue.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#33
I had installed the XP 10s and XP 8s on my Z last fall and while they are a little squealy they worked perfectly at the track and on the street. Any dust washed off easily with Maguiar's Chrome Wheel cleaner. Great pads for what I needed.
#34
But have to see. Selling this car to get the Z06.
#37
Received 1,984 Likes
Rich.... curious how those pretty painted rotors hold up after a track day? All the paints I used, and I did not use that many before I gave up...........cooked off. If yours holds up what paint it that?
#38
I haven't run the C7 on the track but did run our C6 Z06 with rotors painted the same way and the paint held up well on those. I used high-temp paint which has a 900 degree rating. I think the keys are getting everything prepared well, completely clean, using the right paint and applying multiple light coats. Dupli-Color, Rust-Oleum and VHT are the paint brands to check out to get the right color match. I can only speak from our experience but no doubt how hard you run and how hard you brake will determine how well it holds up.
I do have some pictures and information of how we went about it and can send those if you send me an e-mail at: richsclassiccorvettes@***.net We'll be in Carlisle this week but can send them when we get back.
Hope that's of help.
Rich
#39
Rich
I really like the rotor paint job. I will definitely do that to mine this wint...er, I mean, this modification season. I wonder if regular enamel would hold up on a non-track car?
Do have any photos of them with the wheel mounted. Are your wheels bright or black? I would like to see them.
Thank you, Mariano (Alfie)
#40
Rotor Painting
Rich
Our wheels are chrome.
I doubt regular enamel would hold up but I haven't tried it.
Rich
