Master List of How-To Guides for C7 Corvette Stingray
#64
Theta any info on tq sequence and order on the cylinder heads? I see that tq sequence is listed but I don't see the order??
Also anything on removing and installing the fuel rails and DI injectors???
About ready to do a DIY head swap.
#68
St. Jude Donor '14-'15
I would like to add my HOW TO install Flex Fuel Sensor. Confirmed install, it's working perfectly.
https://www.corvetteforum.com/forums...r-install.html
I will add a bottom section that have member 'How-To's that are extremely helpful and proven, including yours.
#69
#71
I'm Batman..
Pro Mechanic
Sean, I think this would be a worthy add to the members how-to's for doing a Tstat swap:
https://www.corvetteforum.com/forums...t-install.html
Ant
Ant
#72
I don't see a rotor replacement how to. I am looking for the torque setting for the Torx Screw that acts as a retainer for the rotor to the hub. In the e-brake how to it talks about the rotor removal but never mentions the Torx screw. Also, the torque for the rear caliper bolts is shown as 89 but does not mention loctite. Is it required on the rear like the front?
thanks
bill
thanks
bill
#75
Incredible set of instruction. Thanks.
I'd love to see a write up on the exchange of the stock radiator to the DeWitts one. Possibly the best mod there is for anyone planning to drive the Stingray as it was meant to be driven.
#76
While swapping front rotors, I stripped the rotor bolt. Anyone know what the part number is for the rotor bolt? While I'm at it, what are the part numbers for the caliper bolts? They're a PITA to clean, I would rather have just used new ones. Thanks!
#80
How to change out a Z06 radiator for a Dewitt's racing radiator.
https://www.corvetteforum.com/forums...6-and-z51.html
