Moisture in headlight lens
I noticed that moisture has entered and dried in the headlight lens' leaving a discoloration on the lens. I first noticed the moisture as a fog when I left the warm garage and drove on a colder morning. Are the lens supposed to be sealed? Can the lens be removed for cleaning?
Received 2,379 Likes
not all headlight assemblies are sealed, i haven't seen the C7 off the car so Papas may be correct, but while the lens is always sealed, many are vented on the back wall.
Finally got a reply from the dealer. There is a GM bulletin on this. The headlights are vented and they say it is "normal" for condensation to form and to drive with the headlights on for a while when starting out. There is no way to clean the condensation marks onside the lens. If this is normal I wonder if it was in the design specs? This is also a problem with the C6.
after warranty expires
I had the same issue here on a C7. Both modules had residue in them after moisture dried. They were replaced today at dealer. I was not advised of a bulletin as stated above.
I'll return to the dealer to request a replacement again. Did your dealer give any advice as to preventing a recurrence?
I've seen cars go thru the water test at the factory and get pulled back after water gets into the lens area. They are changed out and send back thru the water test.
Let me preface this by saying i have not replaced bulbs in my C7 or C6 but isnt there a hole behind the lense enclosure where you insert new bulbs? On my other vehicles this how they are designed. If so then atmosphere would enter the enclosure and depending on the ambient temp and humidity condensation would form. Therefore, I think they have to be vented.
My dealer said there was a C7 bulletin. I've see many C6 and C7 cars with this same problem. The resolution to me was that the district manager gave me an extended 5 year warranty in case the residue inside the lens got worse and it needed to be replaced. Evidently a Chevy representative monitors this forum as he contacted me and offered to get involved to have the car evaluated at another dealer. When I told my dealer that they contacted the district manager.
My car has done this from Day one... It all depends on the environment... I have been driving in some significant weather changes and when coming in from very cold to a nice warm garage this occasionally has happened... and no residual affects...
When I picked up my new 2015 Z51, there was something inside both lights that looked like something had dried inside. Anyway, they replaced both lights and couple months later I found dried water marks inside and they replaced them again. Of course, they said I was too picky but I didn't care and they said that they get paid big bucks to do warranty work, so it doesn't matter what they replace. But they had to take pics and send them off to get approved. It comes down to poor quality or poor workmanship.
bulb replacement
I have had both headlight bulbs replaced at its not cheap...the dealer must remove the bumper to access the headlamp..its not just a bulb replace. ($595 each time)
let alone the water drops inside...living with it. My car was past the warranty period.
Is there any way to get into the headlight assembly without removing the bumper?
I fixed a moisture issue in another car of mine by zip tying a bag of silica gel inside the headlight assembly (away from direct contact with any hot bulbs). Worked a charm and I haven't had any moisture in the headlight for about a year now.
