C7 engine
As mentioned the only engine failures I've read about have come from broken rods or spun thrust bearings---and as it worked out these were NOT caused by bad engine parts but from overheating A6 tramsmissions which take out the thrust bearings--GM is tryning to address the overheating trannys with adding another trans cooler which seems to be the delay on the new Z06 8 speed auto----
Received 2,379 Likes
Pure BS, every bit of the above. The engine/torque tube/transmission case are aluminum while the rotating crankshaft/driveshaft/torque converter are steel...since the coefficient of thermal expansion is different between aluminum and steel, GM used splined connections in the driveshaft. I know it's hard to believe a GM engineer could actually think of something so complicated. Overheating is not the cause of the delay for the Z06 A8, that was solved long ago...in the future, please research your posts to avoid causing damage to your integrity when you post BS.
ls motors had the same situation with the factory valve jobs.....every engine builder I have talked to has said, even if you don't want to port the heads, we still want to go through them based on the last 10 years of our experience with the LS motors.
it's not something that affects everyone all the time, but if you want it to be right, then you have to do it.
were fine. My ownership of (2)ls1, (1) ls3 (1) Ls6 (2) ls-7 and (1) ls9
gave me no issues. I think the large engine shop's say the same thing!
Because I like car tire flavored ice cream must mean everyone does, right? Not quite.
I assume you pulled your car into your garage and removed the heads to check the valves on each car?
Are you certain you would perceive a valve seat issue on your car? Do you know what to look for? Do you know how it affects engine running characteristics? If there were any issues, how would you, personally, identify them?
Can you say with 100% certainty that none of your cars had an issue or can you only say you didn't perceive an issue with any of your cars and that the only thing you noticed was that they didn't fall apart?
Please elaborate on your post outside of the realm of speculation.
RocknBlue08/3 Z06ZR1, It's a common mistake to think you, as an individual, are representative of a large population. You owned 7 cars out of 501,135 Corvettes made since the LS engine came out.
Since the forum has a million posts much bigger sample than 1 mechnic with little to no head problems. On the Stock LS
engines minus the small number of Ls7's can't include ones going to stainless just because.
Off base again! 501,000 engineS and very small NUMBERS OF ISSUES WITH THE HEADS!
Oh since some builder said. Makes it the gospel.
St. Jude Donor '13-'14-'15
The overheating A6 issue is from the experience in my own car---Even on a cool day the trans will go to 230* driving only intown--Doesn't take a rocket scientist to know that is simply too HOT--I can only imagine the temps on a track day A6 --I've read posts on the internet where OWNERS complain of failing trannys after a race
As far as the A8 is concerned again there are no added tranny coolers for a 640 HP engine--So common sense will tell you those trannys will get even hotter--
Speaking to my dealer as of Oct 20th they still haven't realeased the Z06 for sales yet-
Even though they have presold and continue selling them---So ask yourself WHY ??
If it's NOT the engine then it has to be the trans--- If it were a minor issue they would have corrected it by now and made deliveries---My dealer tells me it's on hold for trans cooling ( off the record as we are good friends)-- So believe what ever you choose
I really don't care--I am not concerned with the issues as a Corvette lifelong lover-I have faith that GM will resolve the issue soon---And I will most likely order a Z06 in 2016
If you think I'm slamming the C7 you can't read my post---I love this car overheating trans or whatever----As I said I installed an aftermarket trans cooler and the tranny now runs 175* Any new release of a new platform may have issues in any brand-Sometimes you just have to be pro-active and quit belly aching and accept
the whole car as an innovation and overlook new model pains--
Amazing...given the chance to improve your integrity, you quote the one place that has the least integrity of anybody. You have succeeded in lowering your integrity to zero...good job!
Don’t think there are any significant LT1 engine issues out there.
Don’t want to risk reduced engine life? Don’t supercharge/turbocharge. The ZO6 LT4 has significant durability upgrades to cope with the additional stress of supercharging. Think the factory engineers know what they’re doing.
So, if you go with forced induction you loose the warranty and should not complain if things don’t go well. Don
You mean LOSE the warranty. One "O".
Loose-not tight
Lose-to be deprived of or cease to have or retain.
BTW, your post has multiple punctuation errors proving you're not perfect either.
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
#33
However, the meaning of my post is not affected, GM provided a means for thermal growth differences.
