'14 Z51 0-60 mph in 3.4 seconds!
So, I'm in the process of having a custom tune by Diablew (06MonteSS), and went out to put some miles on the tune. I decided to try some 0-60 mph runs and came out with a 3.4 second 0-60! This was done with a ported tb, air filter, and Diablo tune (still being tweaked by Lew). The car is a manual, on stock tires with 29 lbs of pressure, and a ton of wheel spin. I set the car in track mode, selected the race setting, and let the clutch out around 2700 rpm. The 46* air temps probably helped as well, but so far tuning is going well. WOT tuning still needs to be done. Needless to say I'm impressed.
Very nice! That is impressive.
level road or downhill?
I thought about that. Depends on what sensor the timer measures. If it's the front wheel speed sensors, than tire spin is irrelevant. If it was the rear tires sensor, with wheel spin 0-60 would be more like 1 sec.
Edit: I think the C7 uses an accelerometer, so wheel spin is not a factor.
Dam fast! Congrats.
How did you do your launch, I tried the launch control but could not prevent the clock from starting as soon as the throttle was pressed. Without launch control damn thing just spins.
C7 acceleration - YouTube
but my timer didnt start till car moved.. reset it after you stop.. make sure you stay on the brake if it rolls timer starts..
I used track mode with the race setting. I let the clutch out around 2500 rpm and the car hooked. It spun at the top of 1st and going into second, and then it hooked again. It felt really good.
i tried all.. think dry gave best results but i could feel it kill power on shift.. stock got 4.1sec best..
non stock but on Michelin Pilot Super Sport
cant find video where i tested it stock.. but i was able to take a tenth or off 0-60mph with launch control off 3.9 vs 4.1
