Road Course Upgrades Review DeWitts, Wilwood Z06 Grills
Old 05-20-2015, 05:36 PM
  #41
CeeSeven
CeeSeven's Avatar
Originally Posted by Theta
I asked, but have not gotten confirmation back. Several other vendors and members here have installed the DeWitts, so while I apologize if I'm inconveniencing you, they are also (potentially) able to answer this.
At the moment, I'm working with a forum vendor to get all of the instructions done for a Z51 -> Z06 transmission cooling swap (as requested), on top of quite a few other things here.
Sorry, man. Didn't mean to get on you. You do a LOT of stuff here and we all appreciate it a lot. Looks like Golden One has the answer.
Definitely looking forward to the Z51 to ZO6 tranny cooling swap -- big time. Thanks !
Old 05-20-2015, 06:01 PM
  #42
Theta
Theta's Avatar
St. Jude Donor '14-'15
No worries. I really had/have no idea on the radiator removal. I can say that when I tried to take it out myself the first go-around (long time back), I didn't see any way of getting it out without clipping it, and certainly no way of getting it back in.
And then I barely uncorked the evap line and *pfffffffffftttttt*...... Was not a good day.
Old 05-20-2015, 07:53 PM
  #43
CeeSeven
CeeSeven's Avatar
Originally Posted by GoldenOne
I did mine last week. I just unclipped condenser and slid in the dewitts. Getting the fan back in was fun!
Thanks much Golden One ! Great news. Mind elaborating on the fan reinstall issue for those of us about to do this rad swap?
Also, Did you have to do anything to the rad lower mounts to gain a little [reportedly] needed space to the hood vent?
Old 05-20-2015, 08:17 PM
  #44
Theta
Theta's Avatar
I'm assuming on a non-SC install without that hose extension, the fan snugs really darned tight to the hose.
Old 05-20-2015, 09:37 PM
  #45
GoldenOne
GoldenOne's Avatar
i have supercharger and space is limited even before adding this bigger radiator. i basically wrestled the fan into position. i had to trim plastic radiator shroud so it would sit lower but that is due to supercharger hoses again. it was sitting higher on passengers side.
Old 05-21-2015, 07:32 AM
  #46
leadville1
leadville1's Avatar
The DeWitts radiator is so efficient that I really have a hard time getting the car up to temp on the street. When I drove it up to Road America the bars on the tachometer never stop illuminating over 5k rpm, that is how cool everything stayed on the road.
Up at the track the temps were just amazing, never went past 220. I also highly encourage others to seriously considering the Wilwoods, the brake pedal feel is out of this world.
Without a doubt the stiffest caliper I have ever felt on a car, and the Wilwood consumables are far less than competitors.
Old 05-21-2015, 03:51 PM
  #47
VThokies
VThokies's Avatar
That is great news. So I imagine that the Dewitts radiator and the stock thermostat would be the best combination for a street / track car? I am assuming you are not using the stock thermostat?
Thanks for the information.
Old 05-21-2015, 08:02 PM
  #48
descartesfool
descartesfool's Avatar
220 on track! That's a great result.
Old 05-25-2015, 12:08 PM
  #49
CeeSeven
CeeSeven's Avatar
Report on running some changes to my setup.
Car: 2015 C7 Z51
Previous temps: 280° oil, 290° trans, 240° coolant after only 6- 2.6 mile laps. Ambient: 83°, Brakes: stock calipers, PFC 08 front pads, stock rears. Good balance. Boiled new Castrol SRF (590 dry boil 518 wet) causing track exit.
Previous highway temps: 220° oil, 150° trans, 220° coolant (at most any normal Arizona ambient temp).
Previous tires: Stock Mich PSS front: 245/35ZR/19, diameter 25.8, rear: 285/30ZR 20 dia. 26.5
Changes:
AP Competition disks and rotors, Ferodo FRP3003W pads
Tires: 305/650/18 Continental full slick (diameter 25.5)
Rims: 10.5x18
DEI wrap on exhaust by transmission.
Home made aluminum heat shield between catalytic converter and oil cooler covered on Cat side with DEI self adhesive reflective foil. Yes the adhesive did not melt. Surprise.
DEI Radiator Relief (water wetter) 32 oz replaced that much stock coolant and engine brought up to operating temp and cooled twice prior to driving to track (175 miles).
DeWitts radiator NOT put in yet.
Report:
On 2.7 mile Inde MotorSports Ranch track (Willcox, AZ), fast and technical, 9 laps/20 min session
Tires fit in car ok with limitations. i,e., limited to one turn of steering wheel without rubbing (at 1-1/8 turn) on brake air deflector (not a problem for me). They stick out just proud of fender lip (with 2° neg camber) and rub slightly on track when suspension is depressed on limit of adhesion cornering coupled with little bumps. Did not damage rolled edge of Expel Ulitmate 8 mil car bra. However, the square setup I personally really like. I could drive the car at the limit of tire adhesion (in Track/Race) and steer it with the gas pedal MUCH better than with the stock size offset front to rear and MUCH better than in the other modes which make the car numb and unpredictable (and heats brakes).
Track Max Temps: 240° oil, 240° trans, 220° coolant !!! Ambient temps 65° AM rising to max 75° WOW ! Pleasant surprise. Same each session at maxed out speed for tires.
Brake temps: never got above 300° at the front calipers (used temp strips) -- and I ran most every corner as deep as possible. What a difference lighter, better built, better cooling brakes makes. Big weight savings too. Brake fliud at caliper that has been bleed previously after hot temps on stock caliper was darker. Fluid bleed this AM was clear. Sessions had at least one hour between and I cool front brakes in the paddock with 150 CFM 2.6A boat bilge fans into the brake duct (3"ABS angled up into brake duct just before exit to wheel well. Fits in there well). I'll post some pics if anyone's interested.)
Highway driving: 180° oil, 140° trans, 180° coolant.
Conclusion: DEI exhaust wrap and Radiator Relief really work !! Tires fit ok, but with limitations. Would need fender flairs for continuous running. Cannot use wheel spacers to increase inside clearance for more turning (judged not a problem because I never turn the wheel that much anyway because not needed on track and causes wheel hop in paddock. Even stock tires hop at wheel lock). I will install the DeWitts anyway to lower temps even further. But unless these temps increase significantly with hotter ambient temps (I usually don't run in over 90° ambient by choice) the DeWitts will be only for the horsepower and parts longevity benefits of running coolers temps and I won't try retrofitting a ZO6 A8 tranny cooling setup or adding a fan to the stock tranny cooler -- yet.
Edit: A note that most likely affected the temp changes as well. The previous temps were recorded at AMP, a track with a 94db sound limit. So I was running in "Stealth" mode keeping the outside exhaust actuators closed since I busted that limit the last time out without letting out of it past the "listening posts." My service manager (after replacing those valves from being melted) said not to run with those valves closed on track because it causes "excessive back-pressure and therefore additional exhaust heat," although, FYI, it was the forward actuators that failed, not the outside downstream ones.
So, probably your temp changes for a similar group of changes will be less -- and, a word of warning for heat AND the warranty issue (as soon as Chevy issues a written disclaimer).
Old 05-26-2015, 11:28 AM
  #50
CeeSeven
CeeSeven's Avatar
I was asked to post some pics of the oil cooler shield I fabricated on another thread. So I'll do so on this thread since it is in better context here. Please keep in mind that this was a home made job with in-shop materials. It would be one piece if I had aluminum plate wide enough and a one piece strap to the spare hole next to the oil drain plug if I were good enough to do all that weird angle bending and not weaken the aluminum from too much bending. I'd also weld everything if I could weld aluminum. So go easy on me. I'd still make it out of the 1/8" material though rather than thin sheet because it is mounted to the engine - vibration.
The stick-on heat shielding is DEI material. I had doubts about the adhesive's ability to stay stuck right next to the cat. But after one track weekend it's still there.
See the post above for effectiveness.
Old 05-26-2015, 11:46 AM
  #51
Higgs Boson
Higgs Boson's Avatar
Received 2,379 Likes on 1,238 Posts
how much wrap did it take to do both pipes by the trans? did you do one slightly overlapping wrap or did you go out and back (double wrap)?
Old 05-26-2015, 12:42 PM
  #52
CeeSeven
CeeSeven's Avatar
I bought a 50' roll and used about 35' of it for both pipes wrapped as DEI instructs: 1/4" overlap except more overlap at beginning and end to make the folded over ends captive. It frays as soon as you cut it off (with scissors-easy to cut) and cannot be torched as you would synthetic fabric. Heating with a propane torch just chars the material and it becomes brittle. So wrap as instructed by DEI. It necessarily overlaps more going around pipe clamps and on bends, so I just tried to maintain 1/4" on the outside of the bend and just did the best I could around pipe clamps.
A note about the stainless pull ties you'll buy to secure the ends: You can't pull them tight enough like a plastic wire tie without a little technique. I pulled them as tight as possible with a 2 handed approach: hold the clasp with a flat head screw driver and pull the tie with long nose pliers. That would get it tight enough for the second part: grab the tie end next to the clasp with long nosed pliers (at a point the plier ends are getting a little bigger) and twist the pliers backwards against the clasp and toward the clasp forcing the tie to tighten. It distorts the end of the clasp slightly. But the clasp did not break and it tightens nicely and stays. All other methods I tried resulted in loose ties.
They come in packs of way more than needed so you don't need to worry about messing some up.
Old 05-26-2015, 12:56 PM
  #53
Higgs Boson
thanks
Old 05-26-2015, 01:34 PM
  #54
Rob Willis
Rob Willis's Avatar
You wouldn't consider making another one to sell to me, would you?!
Old 05-26-2015, 01:45 PM
  #55
SBC_and_a_stick
SBC_and_a_stick's Avatar
The heat shield is brilliant. I'm in for one if you can make extra.
Old 05-26-2015, 04:11 PM
  #56
CeeSeven
CeeSeven's Avatar
Yeah..... I don't think so. I'm trying real hard not to make yet another business. But there are some REAL fabricators on the forum who will probably run with it soon. So, in the mean time go to Home Depot and buy some 1/8"x3" aluminum angle and a rivet gun. I just took a picture, sized it to actual dimensions and made a flat paper template to get rough cutting and drilling dimensions and locations. I cut it up on my band saw (for wood with a bi-metal blade) or a plain old jig saw would work fine. Then fit and refine -- about 5 trips in and out from under the car, and voila, a real messy but functional shield.
Note: Do Not attach anything to that nice flat strap that begs you to drill into it. That would be joining the body and the engine. Crack.....Ripppp......
Oh, and use some anti seize on the 8x1.25mm x 3/4" bolt you buy assuming you can get only nickel plated. That will cut down on galvanic reaction (corrosion)that would get started because the aluminum is in contact. Then use a split washer on it so it stays put. Don't use stainless steel. It doesn't get along with aluminum at all. Ideal would be one of those fancy Chevy galvanized bolts, but I couldn't find one.
To the guy asking for pics of the DEI exhaust wrap: I'm going to be on a lift tomorrow to return car to street alignment for the summer. Will shoot a pic while it's up and post tomorrow.
Old 05-26-2015, 04:27 PM
  #57
descartesfool
Here is a top view of the exhaust pipes near the transmission with the black AFM actuators (posted by Theta).
Sample pictures of exhaust pipe wrap job near transmission area with DEI Titanium wrap done from under the car are here:
https://www.corvetteforum.com/forums...post1589235531
Post #27
Without taking the mufflers off it is virtually impossible to wrap the entire exhaust pipes around the transmission area as there is just no access. I plan to take off the rear bumper/valence and remove the mufflers and wrap them off the car.
To Road Course Upgrades Review DeWitts, Wilwood Z06 Grills
Old 05-26-2015, 04:37 PM
  #58
Higgs Boson
I'll probably just avoid wrapping it until I get a B&B from Ben@WX.
Old 05-27-2015, 08:26 PM
  #59
CeeSeven
CeeSeven's Avatar
Pics of DEI exhaust wrap and a better one of the oil cooler heat shield.
Old 05-28-2015, 04:07 PM
  #60
Magister Ludi
Magister Ludi's Avatar
Thank You! This is really useful info.
Quick Reply: Road Course Upgrades Review DeWitts, Wilwood Z06 Grills
