Track guys... GoPro and data overlay help...
Cruise-In II Veteran
Cruise-In III Veteran
I have a 2014 stingray, sadly the PDR wasn't available at that time and it is one of the features I most miss as I enjoy tracking the car, just not enough worth it at this point to trade the car as I have modified car and am otherwise happy with it.
I have a GoPro 3, I believe there is a way to use some type of OBD II device and computer software to somewhat mirror the functionality of the PDR. I already use the GoPro to film my HPDE but would love to have track overlay, throttle, rpm, etc... Any suggestions on the EASIEST setup for this type of thing would be appreciated (user friendly, etc)
I know garmin makes a complete kit for this but I already over the gopro 3 silver +, also I have an iPhone and I use a mac computer. Any suggestions are appreciated. If computer software is involved, hopefully it will work for Mac. THANKS FOR YOUR HELP
Received 2,382 Likes
I use HPTuners RaceRender
You can use TrackAddict to record on the phone and do limited telemetry (GPS really) but it also supports a bunch of wireless OBDII adapters to get the data from your car on the recordings through the phone. TrackAddict can also connect to your gopro to start a recording there at the same time.
http://racerender.com/TrackAddict/Features.html
I believe most of the adapters listed there would work for Harrys lap timer as well
That would be the -easiest- way to get it done
I own an HPTuners cable so I usually just connect it in the car and start logging on my little netbook. At AutoX I put the netbook in a book bag and then buckle the book bag into the passenger seat. When I get home I use RaceRender to pull the video together with the logged data. Since TrackAddict and RaceRender are both made by the same company you can also pull videos and data recorded from TrackAddict into RaceRender very easily to get more powerful editing.
This is a video I use as an example quite often
The forward video is from my iPhone in a ram mount, rear video from my GoPro Hero 4 silver. The Track map and G-Force information came from TrackAddict on the phone and the rest of the car data was from HPTuners logs. I was able to pull all 4 sources together in RaceRender.
RaceRender is a neat piece of software as it can work with logs from almost anywhere. This is a video I put together using logs my buddy recorded from his GTR using his ECUTek tuning suite
I use RaceChrono. It's $20 for the premium version. The only thing that bugs me is the annoying little brand stamp in the corner. I'd like to try Harry's Laptimer, but everyone says that the phone screen has to stay on while it's recording, which I think is ridiculous. If you're at an all-day track event and you want to record multiple sessions, you're going to have a hard time keeping your phone charged.
This is the ODB scanner tool I use (but I have the older version, which is blue): http://smile.amazon.com/dp/B005NLQAH...332200_TE_item
I don't know if it's the scanner's fault or the app's fault (or my fault), but I can't seem to get a brake level signal into the video.
Here's a video I made with RaceChrono:
obd 2 scanner says for android only I have iOS :(
do they make a version that works with iOS latest version? I have an iPhone 6s plus, thanks
Here's a video I made with RaceChrono: https://www.youtube.com/watch?v=y2QrNXZLjTo
TrackAddict is free to try and you only have to get the paid version if you want to seriously start using it as the free only lets you keep so many videos.
You will get the GPS and gforce data from the phone to try at least and if you want the OBD2 they have a list of adapters they recommend that work with track addict.
This video was done with just TrackAddict and the built in sensors on the phone, no external data as I didn't have my data logger on me.
Here's a list of recommended devices:
http://www.racechrono.com/forum/#/di...periences-here
Just to update.. After this thread renewed my interest and reminded me I wanted to try a WiFi OBD2 adapter for trackaddict I bought this one for $16 shipped on amazon. It's not on the recommended list but from what I saw they all use the same chipsets these are just chinese knockoffs.
I tested it using TrackAddict on my iPhone 6s in my 2016 Cruze Limited since there's a ton of snow and salt around. I am very happy with it's performance and can't wait to use it at AutoX with my C7.
I see that there's no brake signal overlaid in the video. Are you able to see a brake signal at all?
When I was playing with the ODB2 PIDs to log I found Brake but all it did was indicate when the brake was touched and not a percentage. Mind you this was on my Cruze and not the C7 but I'm not sure if Brake % is something available through OBD2 on the C7?
Originally Posted by Rob Willis
Watch some PDR footage on youtube from 2015 C7s. The brake graph/scale is very inaccurate.
