Anyone had their electric assist pump go out?
anyone had their electric power steer pump and rack out? I marked it all when I took mine out but could be off a few teeth?
Basically the electric pump/motor has a small fine belt that runs the rack. It all works fine but when I crank it all the way I sometimes get a popping kinda noise,,,,,,,, I assumed the motor and or rack have a sensing device to know pressure so to speak. The alignment of course never changes since its a belt running it. I wonder of I have an issue with the electric pump maybe? double and tripled checked all the bolts in the rack and front end and its all tight??
Any thoughts would be great, thxs hanny
I cant imagine these things have to be indexed? unless I screwed up and did something wrong? I double and triple checked all bolts. wonder if its not my fault and/or I need to take it in? thxs for reply. hanny
I decided to remove the motor from the rack because it was up in the air and quicker/easier (took like a minute to unhook motor from rack) then unhooking cables that run to it and disconnecting the battery, might of been a mistake the way it sounds?????
The motor actually runs a small belt if you can believe that, I kinda thought it would be gear to gear but when i went to put it back together I was like "theres a belt inside the housing,,,,, that's strange?" LOL.
I';ll dop some more digging and find out if it needs indexed but I cant imagine it would? thanks for responses 3x2..... appreciate the input. take care, paul
