Spring Savings on LG Super Pro Exhaust Systems
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
LG Motorsports
The original bolt on long tube header set for late model C7 Stingray and C7 Z06 Corvette.
LG Motorsports Super Pro series of headers are constructed of 304 stainless steel and tig welded. All of the super pro's use our racing merge collectors with built in fire cone for the ultimate in exhaust scavaging. All of our Super Pro's come with a limited life time warranty to the original purchaser.
Our headers are designed as a modular slip fit design so you can add or remove cats as needed and the slip fit design does not reduce ground clearance while keeping a smooth inside flow through the pipes with little to no disruption.
Included with EVERY set of LG Super Pro Headers
- All clamps
- new GM exhaust gaskets
- All required 02 extensions or adapters
- Full 3" mid section
- High flow Siamese X pipe
Options.
- High flow cats (off-road pipes are included either way)
- C5 / C6 / C6Z your choice of 1 3/4 or 1 7/8 Primary
- C7 / C7Z your choice of 1 3/4-1 7/8 stepped or 1 7/8"
- Jet Hot coating
Through the entire month of May:
5% off AND FREE SHIPPING within the 48 US.
C7 Stepped Pro's shown here.
Connects to stock mufflers with no modifications
A6 Stingray dyno before and after LG Super Pro's.
M7 Stingray dyno before and after LG Super Pro's.
