Z06 wheel offsets
Alcoholics Unanimous
Received 1,654 Likes
St. Jude Donor '15-'16
Z06 wheel offsets
Hi,
I'm starting to investigate a set of aftermarket wheels for my Z06/07 and I can't find the offsets for the OEM wheels front and rear.
I'm going to purchaser the exact same size wheels so I can use my existing tires but it bothers me how they slightly tuck in ... so I'm figuring 10 or so mm less than the OEM offset should line them up with the fender extensions both in the front and the back.
I can't imagine that such a small offset difference would have any adverse effects such as creating rubbing but please let me know if that's not the case or I'm missing something.
TLDR: what's the offset of the Z06 OE rims?
Thanks.
Thanks.
Eli-Z06 (02-20-2019)
Check with Ben at Weapon X. He has the offsets. I ordered a set of Forgeline wheels from him and Forgeline indicated that they felt we could push out the wheels slightly (8mm in front and 9mm in the rear). Forgeline has their own Z07 to do their fitting.
GNTZ06 (06-23-2022)
Ben has a thread on it here:
https://www.corvetteforum.com/forums...t-to-know.html
Copied from Ben's thread:
Doing some research for my new wheels and thought I would share the difference between the Z06 and Stingray wheels and tires!
vs.
Front wheels:
C7 Base and Z51 front wheel (respectively)
18x8.5 ET 56mm
P245/40ZR18 (93Y) SL Michelin® Pilot® Super Sport® ZP
19x8.5 ET 56mm
P245/35ZR19 (89Y) SL Michelin® Pilot® Super Sport® ZP
vs.
C7 Z06 front wheel
19x10 ET 43mm Listed weight of 25.7lbs.
285/30ZR19 (87Y) SL Michelin® Pilot® Super Sport® ZP
Result:
Suspension clearance: Z06 wheel is 7 mm (0.3'') closer to suspension/brakes components. Acceptable for most cars.
Fenders clearance: Z06 front wheel will stick out 33 mm (1.3'') farther.
Wheelwells clearance: The same.
SPEEDOMETER: The same.
________________________________________ ____________________
Rear wheels:
C7 Base and Z51 rear wheel (respectively)
19x10 ET 79mm
P285/35ZR19 (99Y) SL Michelin® Pilot® Super Sport® ZP
20x10 ET 79mm
P285/30ZR20 (95Y) SL Michelin® Pilot® Super Sport® ZP
vs.
C7 Z06 wheel
20x12 ET 59mm Listed weight of 31.8lbs.
335/25ZR20 (87Y) SL Michelin® Pilot® Super Sport® ZP
Result:
Suspension clearance: Z06 wheel is 5 mm (0.2'') closer to suspension/brakes components. Acceptable for most cars.
Fenders clearance: Z06 wheel will stick out 45 mm (1.8'') farther.
vs.
Front wheels:
18x8.5 ET 56mm
19x8.5 ET 56mm
vs.
C7 Z06 front wheel
Result:
Rear wheels:
19x10 ET 79mm
20x10 ET 79mm
vs.
C7 Z06 wheel
Result:
Supporting Vendor - Supporting Member
The C7 Z06 suffers from the same unaggressive offsets on the stock wheels as the 6th gen Z06/ZR1/GS. We can build a Forgestar set with a 30/50MM that will be more aggressive than the stock 40/59MM. Check out our listing for the Forgestar wheels below. The 30/50MM offsets are shown on all of the corvettes pictured in our thread. Pm, email, or give us a call for any questions.
FORGESTAR:
https://www.corvetteforum.com/forums...ar-dealer.html
FORGESTAR:
Dark pic, but check out the aggressive oem offset on my Z28:
... and it's like that in the back as well, and that's with the oem fender extensions.
Now those are sticking out about an inch which is probably too much for the Z06, but I'd like my rims to at least be even with the Z06's fender lips if not sticking out a few mm.
So what do you guys estimate the offsets need to be to achieve that?
(thanks for all the help btw)
Supporting Vendor
We have the new Z offsets and fitments all give me a call anytime
440-915-6166
440-915-6166
__________________
#1 Forged Wheel Master Distributor for Corvettes Worldwide since 2010
Call/Text 440-915-6166
Forgeline*Anrky*HRE*PUR*Brixton*Vorstein er*Akra*Brembo*IPE and Many More....
REVIEWS: http://forums.corvetteforum.com/whee...r-reviews.html
WEBSITE: www.cw4L.com
EMAIL: sales@cw4L.com
PHONE 440-915-6166 CALL OR TEXT ANYTIME!!!
Follow us on Instagram @custom_wheels_for_less
Looking to BUY offset info for BEST LOOKING fitment
on my 2012 Grand Sport.....................
Using 18x9.5 Front Forged Alloy
and 19x11.5 Rear
LOOKING to SEE good pics of Custom Wheel Fitment
showing Wheel Relationship to Body Sideline
Name your price at CamarosRus@gmail.com
or 253-263-5190
and 19x11.5 Rear
or 253-263-5190
Hi,
Thanks.
Thanks.
C6/Z06 (and GrandSport) OE Front 18x9.5 Offset is +40
and OE Rear 19x12 is +59
I am asking for experienced member(s) to share best
offsets for custom wheel fitment on C6/Z06
Im wanting to use 18x9.5 Front and 19x11.5 wheels rear
I can use WHEEL OFFSET CALCULATOR to convert
YOUR Best Fitment Offsets to my wheel sizes
Thanks, Chuck
Thanks, Chuck
This is plus 8mm in the front and plus 9mm in the rear. Stocksize tires and wheels are stock 19x10 20x12
BC Forged
mine is a Z06/07
BC Forged
mine is a Z06/07
swaite, May I assume the OE C7 Z06 19x10 Front Offset is +40........(My 2012 Grand Sport 18x9.5 Front are +40)
May I assume the OE C7 Z06 20x12 Rear Offset is +59.......,(My 2012 Grand Sport 19x12 Rear are +59)
Could you please CONFIRM What size Wheels (dia &width) and What Offsets your BC Forged Wheels Are ???
Could you please CONFIRM your front/rear Tire Sizes ???
Could you State the Finish on Your BC Forged Wheels as I want a finish Somewhat LIGHTER than yours
I would like to use the Wheel Offset Calculator Tool and convert your offsets to be used on my
18x9.5 and 19x12 Forged Alloy Wheels
Chuck Sharin
Auburn, WA
Chuck Sharin
Auburn, WA
I really not sure its whatever stock Z06 wheels are. The wheels are moved out 8mm in the front and 9 in the rear. The tires are front: P285/30R19 rear: P335/25R20
i went with the continental DW non runflats for this set
wheels are 19xx10 20x12
Chuck Sharin
Auburn, WA
Chuck Sharin
Auburn, WA
Swaite, I'll confirm elsewhere what the offsets are on C7/Z06 19/20" wheels ....and then your Custom Forged Wheels
are out 8mm and 9mm from OE Stock.
Sizes of the C7/Z06 Wheels:
and may we assume that the tire has never hit/rubbed the painted "inside" edge of Fender/Qtr Pnl ????
Thanks again
- Offset: Front 43, Rear 59
- Size: Front 19x10, Rear 20x12
Thanks again
Thanks again
Thanks again
the tires are no where near rubbing on the fenders
