Sponsored by: GEM Motorsports
Remove coolant drain plug
Old 04-28-2015, 03:07 PM
sushisean
sushisean's Avatar
Default Remove coolant drain plug
where is the Coolant drain plug on the radiator? It was a simple hand wing nut on my c6 but I just see two holes on the car
Old 04-28-2015, 07:07 PM
ncrowe
ncrowe's Avatar
same question - want to drain and add water + water wetter
Old 04-28-2015, 07:33 PM
lawdogg149
Support Corvetteforum!
lawdogg149's Avatar
I believe I saw it on the passengers side now. I briefly remember it surprising me.
Old 04-28-2015, 09:22 PM
sushisean
sushisean's Avatar
It's on the drivers side, to the left of the side of the radiator. Look for a white plastic **** that sticks out parallel to the ground. It's a bit tucked away under a shrowd so you won't necessarily see it as soon as you look up.
Old 05-25-2015, 05:57 PM
Jwood02
Jwood02's Avatar
Default Bleeder?
I drained the radiator in my Z06 but it won't take the 2.5gl I took out.
Is here a bleeder valve in the system? I must have air in it.
Old 05-25-2015, 09:50 PM
sushisean
sushisean's Avatar
Just opening up the drain plug you're only going to get about 1/2 the fluid out. You need to run water through it if you really need to flush everything. I just let it drain until stopped and then topped off with all distilled water and water wetter, that'll get you pretty close to the desired 80/20
Old 05-26-2015, 10:06 AM
TEXHAWK0
TEXHAWK0's Avatar
Did you start it up and let it warm up until the thermostat opened?
Old 08-03-2015, 09:06 PM
DLC7
DLC7's Avatar
Made it easy...thanks sean
To Remove coolant drain plug
Quick Reply: Remove coolant drain plug
