Dyno Z06 A8
Dyno Z06 A8
In what gear are people/tuners dynoing the A8 ? Thanks
Former Vendor
We dyno A8's in 5th gear. Gets up to the 160 range in 5th.
Former Vendor
We hit speed limiters in 6th gear on the Mustang MD1100. Dyno is good at 220mph but seems the run lasts forever lol
We tune in 5th and are very happy with ending tuning results
racerx8 (10-19-2015)
Thanks for the replies. We used 5th this morning, figured 6th would be too fast...lol.
6th gear is the most desired for the A8 because the input/output shafts are "locked" together and there is no power flowing through any meshed gears meaning no HP losses to gears in the transmission. However, all chassis dynamometers have speed limitations with most models not being able to go over 200 MPH...the top of 6th with an A8 is over 210 MPH. You'll need to find a chassis dyno with the correct speed range to dyno in 6th or you'll have to use 5th.
If my last assertion is true, you should be able to run in an underdrive like 4th and keep the wheel speed down. A -quality- dyno operator should be able to tell you if that's practical or not, it's more of a guess. Looks like a few above are doing it though!
The important thing here is that in 6th gear, there are no gear teeth in the planetary gear set slipping against each other while transmitting full input shaft torque. This reduces parasitic losses.
Contrast this to a conventional 1:1, in which two 1:1 gears incur gear tooth slip, and load-dependent parasitic loss, as they rotate against one another.
The following 3 users liked this post by RedLS6:
