Canadian Events Canada, eh?
Anyone know who sells Chevron Techron Fuel Injector Cleaner in the GTA?
Old 05-17-2013, 07:27 PM
piran21
piran21's Avatar
Default Anyone know who sells Chevron Techron Fuel Injector Cleaner in the GTA?
anyone know ofa Source
Old 05-17-2013, 07:40 PM
Mad*Max
Mad*Max's Avatar
Received 1,500 Likes on 817 Posts
nobody - you'll have to get from the US (Amazon has)
Old 05-17-2013, 07:47 PM
infernobuster
infernobuster's Avatar
Just use seafoam.
It will do a better job.
Old 05-17-2013, 09:59 PM
sami85L98
sami85L98's Avatar
Seaform works good as well but techron even better...hahah. Unfortunately its only in US. However someone posted a while back, alberta has it and he can ship to ya, search in canadian section type techron see what comes?
Old 05-17-2013, 10:20 PM
Patman
Patman's Avatar
Received 1,920 Likes on 1,192 Posts
Another great choice is Gumout Regane complete fuel system cleaner, sold at Canadian Tire. I know this stuff works extremely well because I was having a problem with a leaky injector on my 2006 Civic, as evidenced from my oil analysis report that showed 7% fuel was getting into the oil. Plus when the car sat for long periods of time (a day or more) it had a hard starting problem (it would crank for quite a while before actually firing up). After using this cleaner, my Civic's engine now has no problems starting even when it sits for a full week, and my last oil analysis report showed a drastic drop in the level of fuel in the oil (only 2%)
Old 05-17-2013, 10:37 PM
piran21
piran21's Avatar
I'm having the fuel gauge issue...thats why
Old 05-17-2013, 10:49 PM
WildWilly55
WildWilly55's Avatar
If you use Petro Can (ex Sunoco) Ultra 94--it has techtrol instituted in the fuel.
Old 05-17-2013, 10:50 PM
Patman
Patman's Avatar
Give the Gumout stuff a try first, it's easy to find at any Canadian Tire and I bet it will get the job done. And if for some reason it doesn't, then try Techron afterwards.
Old 05-17-2013, 11:01 PM
CanadaGrant
CanadaGrant's Avatar
I had the same problem with my 02. I started using Chevron and still had the problem so mentioned it to the GM dealer here and he said their GM fuel system treatment would clear it up. It did and that was 5 years ago and has never reocurred. The longer you can leave it in the tank, the better so if your going on a big drive, it will clean your injectors but needs time in the tank to work on the sender.
Old 05-17-2013, 11:13 PM
piran21
piran21's Avatar
thanks all.
Old 05-18-2013, 06:58 PM
JUSTAKAR
JUSTAKAR's Avatar
thanks all.
Powellraceshop always keeps a few, in Port Perry.
Hath Ian
Old 05-19-2013, 11:15 AM
Airwilf
Support Corvetteforum!
Airwilf's Avatar
I have 5 or 6 in my garage,but I'm in Beamsville.If you cruise towards Niagara ew can meet at the QEW & Ontario St.Beamsville.
Old 05-20-2013, 08:28 AM
WildWilly55
I also have a spare bottle you are welcome too in Guelph if all else fails!!
To Anyone know who sells Chevron Techron Fuel Injector Cleaner in the GTA?
Quick Reply: Anyone know who sells Chevron Techron Fuel Injector Cleaner in the GTA?
