How to remove water spots!?!
Well, I am VERY CAREfull about where I park my vette to avoid sprinklers.. but the other day, I went to a bar, parked out in the boonies to avoid the dumb drunk guy smashing the side of my car... and when I came back, I noticed sprinklers had come on while I was inside...
Now there are terrible water spots... what can i do to take them off? is there a solution out there? I have not waxed my vette yet.. which I'm sure made them worse.. but there are a lot of minerals in the water where I live..
Suggestions?
Suggestions?
Originally Posted by Slash
wash the car?
I used Meguires Swirl Remover which took it right off. Clay bar wouldn't touch it.
BTW, I had a very good coat of NXT and Booster on it. Ran through some road paint that was still wet and was able to get it off, but the water spots had to be buffed with the swirl remover.
Perhaps someone who is better versed in car care can address whether this is actually GOOD for your paint or not but a 50/50 mix of water and vinegar will take them right out. I used to do this on my WS6 when my neighbor lacked sprinkler courtesy and it did not seem to damage the paint after MANY repetitions.
Good luck!
Good luck!
Good luck!
Good luck!
Originally Posted by zonsolo
Car like that and no wax??
Check over in the Car Care Products section of the Forum. There have been any number of threads on this topic going around over there recently. Here's just a few of the more recent ones:
http://forums.corvetteforum.com/show...ts&forum_id=10
Good luck.
Good luck.
Originally Posted by sandmanusd
ha, easy now... I havn't had time.. you have to realize, its been on average 105-110 for the last 3 weeks... I work nights, so that leaves morning time for sleep and day time for... not being in the sun... cant very well wash and wax a car in 110 degree sun... a dilema!!
I was just bustin' your ***** anyway. I hope those come out for you.
for me:
clay bar doesn't touch them
vinegar, even full strength had no effect at all.
used 3M fine cut rubbing compound BY HAND
BEFORE
AFTER
The results above were on an outside vehicle ignored for 3 years with deep etched in water spots.
Since then I've found that scratchX works quite well by buffer, and it will also work quite well by hand - only for relatively fresh water spots.
my suggestions for you:
1. Start with Meguiar's scratch X - the least abrasive. by hand if you have to, but buffer with a white pad is better.
2. if that doesn't work, step up to 3M swirlmark remover (39009)
3. If that doesn't work, step up to 3M fine cut rubbing compound (39002)
If this just happened a few days ago, I'd bet the the scratch X with a buffer will get them out in about 3 seconds.
BEFORE
AFTER
Originally Posted by AZC5
2 words.
Clay Bar.
Then put a good coat of wax on her.
AZC5
Clay Bar.
AZC5
Moderator
Received 3,622 Likes
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'12-'13-'14-'15-'16-'17, '21
Hi-what about water spots on the windows and Glass top? Thanks!
Originally Posted by TripleBlackxTwo
Clay bar wouldn't do anything for the waterspots I just had. I was very suprised. But Meg. Swirl Remove took them off easily.
Originally Posted by Batmbl
Clay bar didn't touch mine either. 80/20 mix of water/vinegar worked immediate wonders! Followed that with good coat of NXT.
Great stuff. Just make sure NOT to use it on plastic -- I made this mistake, not knowing a headlamp cover was plastic -- it scratched the hell out of it. Use on glass only.
