Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Ask the Autogeek! Question & Answer Thread
Old 12-09-2016, 01:39 PM
  #1001
bigcypress
bigcypress's Avatar
hello sir , i keep reading about ''ceramic'' waxes/sealers for lack of a better term . i googled ''ceramic'' and it replied ''pots and other articles made from clay hardened by heat.'' i don't understand the connection between this definition and waxes/sealers . also i've purchased some wolfgang ''uber'' as i've started the two bucket rinseless wash and like it a great deal . along with the uber i got a 5 gallon bucket and grit guard . i've read peoples suggestions about the two bucket method with grit guard in wash solution bucket . it makes more sense to me to use bucket with grit guard as the one to rinse off the wash mitt against the grit guard and then get clean wash solution from non grit guard bucket which would contain uncontaminated wash solution . have i overlooked something in my conclusion ? by the way , i read the uber booklet and it has a claim i've seen in other car wash product ads , it is the term ''encapsulates the dirt '' i am dubious about this . i repeat , love the uber and am tempted to try other wolfgang products if i live long enough to use up my zaino . . . peace
Old 12-09-2016, 09:25 PM
  #1002
0Killrwheels@Autogeek
Former Vendor
Killrwheels@Autogeek's Avatar
couple of great questions here ... I'll try to help.
Coatings are the newest offerings far surpassing the length of protection of traditional waxes and paint sealants (aka synthetic waxes). Their design and makeup is commonly ceramic based or some are silica based. These ingredients are designed to help the coating not only last longer, but often protect better. The challenge is that the amount left on paint is quite thin and this limits the ability to protect paint from scratching and rubbing. Once cured, most coatings are far more beneficial than a traditional wax or sealant.
The "best" or "proper" way to wash a car has been established as the two-bucket method. One bucket has the clean wash solution or soap, the other clean rinse water. Grit Guards are certainly an additional way to control the dirt being removed from mixing with the clean soap or rinse water. For best results, you likely should consider one in both buckets. Some will even now add a foam gun into the mix to presoak prior to washing as another level of wash. What we know is that washing and drying is where most scratches and marring is introduced to paint ... controlling it with good techniques keeps paint in great condition longer.
The Wolfgang Uber rinse is full of ingredients to help loosen, lift, lubricate, and clean paint. Glossing agents are included to look great. There's lots of fancy and scientific terms and ad copy to sell a product. In the end it works as described, looks great ... well then its a valid choice for rinseless/waterless wash needs.
Old 12-18-2016, 10:03 PM
  #1003
binster
Support Corvetteforum!
binster's Avatar
Hi. What's the best way, or is it even possible to remove / clean creases in my leather seats?
Old 12-19-2016, 05:44 PM
  #1004
Former Vendor
Leather in most automotive settings is coated, it has a polyurethane coating on it. When that coating is worn it can crease. Unfortunately there is no easy way to remove the creases and have only heard of moderate success outside of recovering the area or repair.
Now that said, you certainly can clean leather and make it look newer. Leatherique is commonly suggested and its a great two step process, but requires time and effort. You must follow the direction. The other challenge is all the pin-holes in the center of those seats. You don't want to clog them with a product.
I might suggest considering Leathermasters and cleaning the bolsters specifically. You can lightly wipe the center area as desired, but don't use the product directly on it again clogging the holes.
http://www.autogeek.net/strong-leather-cleaner-kit.html
binster (12-19-2016)
Old 01-02-2017, 08:36 PM
  #1005
ronkh57
ronkh57's Avatar
Old 01-05-2017, 08:37 PM
  #1006
rsparks64
rsparks64's Avatar
Is Autogeek killing this too?
Old 01-05-2017, 08:43 PM
  #1007
cmonkey713
cmonkey713's Avatar
Received 1,259 Likes on 920 Posts
Jason, since Scott is no longer on the board will you be directly responding to the posts in Care Care Discussion. The comments on the posts from a house expert is really helpful from a different perspective than asking a specific question. I think we would all also really appreciate you on the discussion board too. Thanks!
Old 02-19-2017, 08:53 PM
  #1008
MKenM
MKenM's Avatar
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Nanoskin mitt vs clay bar. Which do you prefer? Which is easier? Which gives better results? My GS is used only in fair weather. Thanks for your advice in advance!
Old 02-25-2017, 07:58 PM
  #1009
stevette17
stevette17's Avatar
What's the strongest rim cleaner??
Old 04-19-2017, 01:13 PM
  #1010
skar
skar's Avatar
Getting the dust off my black C 6 in between washes . ? California duster or car detailer . You know you are at cars and coffee and you see dust what do you do or use.
Old 04-19-2017, 02:24 PM
  #1011
*El Ocho*
*El Ocho*'s Avatar
I've been wondering the same thing......
Recently compounded, polished & waxed my Black Z06. Now, 2 weeks later it still shines like a ****, but has collected some dust while in the garage.
I use to use a California Duster on my Cobra, but that was silver. Not sure how safe it would be to use on a black Corvette.
Old 04-21-2017, 04:24 PM
  #1012
ronkh57
ronkh57's Avatar
QD or Waterless wash
GOOD micros
Old 04-29-2017, 11:23 PM
  #1013
optiman
optiman's Avatar
Default The next level!
96 deep metallic purple.
Using griots 6" orbital
I'm a newbie
Used orange pad with meguairs ultimate compound then ultimate polish.
Followed by ultimate wax.red pad
Looks great, but still have fine scratches.
Thinking of using meguairs ultra polish kit with 105 and 205 and pads included.
Then black fire ice on fire sealant? Did I say that right?
Suggestions?
Can't afford really high end. Maybe $200 tops maybe little more.
Shipping to Canada
Old 04-30-2017, 10:11 AM
  #1014
ronkh57
ronkh57's Avatar
I prefer M101 better than 105. Less dust, better work time.
Old 04-30-2017, 09:38 PM
  #1015
optiman
optiman's Avatar
I'm a newbie
Suggestions?
Shipping to Canada
Wolfgang kit looks interesting?
Would it cut as much or better then meguairs?
Also was looking at griots.
Is black fire only for black cars?
Old 05-05-2017, 09:35 PM
  #1016
optiman
optiman's Avatar
Isn't the tittle ask Autogeek?
Anyone here?
Old 05-10-2017, 06:08 PM
  #1017
Killrwheels
Killrwheels's Avatar
Anyone here?
Autogeek was purchased by a new owner late in 2016. I was the forum contact and no longer part of the Autogeek staff.
https://www.corvetteforum.com/forums...-autogeek.html
Out of respect for a former employer, I might suggest visiting their website or their forum for questions and current needs.
I will be happy to try and assist off-line thru PM, but would prefer not to offer specific products out of respect for them. Any house brand questions (Pinnacle, Wolfgang, Blackfire ) is best answered by them directly.
The following 2 users liked this post by Killrwheels:
cmonkey713 (05-14-2017), ronkh57 (05-10-2017)
To Ask the Autogeek! Question & Answer Thread
Old 09-23-2017, 10:17 AM
  #1018
CyberGrayGS
CyberGrayGS's Avatar
Default Zaino Z16 Equivalent / WGDGSS
Would you please recommend an Autogeek product that is very similar to Zaino Z16 Tire Treatment? Also, when do you expect to have Wolfgang Deep Gloss Spritz Sealant available again in the 64 oz. size?
Tks, CD
Old 11-29-2017, 04:13 PM
  #1019
okaythen
okaythen's Avatar
How soon should you remove the bumper bugs before etching kicks in? I guess remove them as soon as possible? But if you can't do it right away what will protect the paint from bugs/etching. Does quik detailer help, and clearcoat.
Old 11-30-2017, 06:12 PM
  #1020
ronkh57
ronkh57's Avatar
ASAP bugs can be very acidic.
Clearcoat is paint and will etch, detailer normally won't help either.
Quick Reply: Ask the Autogeek! Question & Answer Thread
