Need some advice on rejex
Okay so I have researched using rejex. I know you wash w dawn, clay bar, re-wash (optional), then apply rejex. My question is this, can I wash with dawn dry the car then apply rejex. I have never clay barred a car and I bought the vette used a month ago. I know it was waxed bc the water beads up and the paint is in great condition. Just need some advice thanks!
The clay bar step isn't completely necessary. Clay barring the car removes any contaminates embedded in the paint, which washing doesn't remove. Not doing this step means you'll be applying the wax/polymer protectants over the contaminants. The end result is the paint won't look as glossy smooth as it could, and the protectants won't adhere quite as well (will last a little less between applications).
Put a plastic bag over your hand. Then run your hand over the freshly washed paint. Does it feel smooth, or do you feel graininess on the paint? That's a good indicator that you really should clay the car.
Former Vendor
Rejex is a paint sealant that is designed to protect paint. It offers alot of gloss and quite slippery. Its also very durable. In order to get the best from "any" paint sealant, you should properly clean or prep paint prior to its use to get the best looks and longest protection.
**Dawn really isnt needed in car care **
Wash --- Clay --- Polish (or paint cleanse) --- REJEX !!
Dawn isn't really a great soap for normal car care. Because it's a pretty aggressive soap, it is mentioned by many for use when doing a complete cleaning of the paint - Dawn to clean and strip any old protectants (wax, Rejex, etc), clay bar to remove contaminants, rewash, then new coat(s) of protectants. But for general use, not a great choice. Since it sounds like you' going for the complete cleaning, it wouldn't be bad for this round, but some people argue it isn't necessary.
Killrwheels - do you think washing with normal auto soap is enough to ensure any old protectants are removed, or do you believe it isn't necessary to remove old protectants? Since the OP doesntknow what's on there now, it would seem Dawn would be a good choice for now?
Former Vendor
I also am NOT a fan of Dawn in car care. I am not here to argue about it, but I believe it was once suggested to remove the oils found in carnauba based waxes. I seriously doubt it can remove all of a well cured paint sealant in one wash. Times have changed and numerous products have been designed to specialize in prepping paint.
I'm planning on switching and trying something new for a protectant, but a machine polish is part of the plan.
I thought that I would take advantage of the BOGO on Rejex at Autogeek and try it on my Arctic White C5. My question is, what is the advantage of a second application? Better protection? Better appearance? The 12 hour curing time is a disadvantage of Rejex but if there will be better results with an additional layer I would certainly wait the extra time.
Former Vendor
Second coat of rejex is not worth it. It's heavy duty stuff and is also used on boats and aircraft. I used it for a couple of years. Little goes a long way. I tried multiple coats, but the best my Silver Vette ever looked using Rejex was when I would wait 24 hours for it to cure and then hit it with a quick wax. It really brought out the pop.
If you feel better, do two coats the first time around. But you really do have to let it cure a while before doing anything with it.
Thanks for the replies. I'll try one layer first and see what the results are like. The quick wax idea is one that I might try as well. White is a tough color to do much with anyway.
Just a follow-up on Rejex. I did the works on my C5 and I must say it looks great. I didn't think it could look better than it already did being Arctic White, but the combination of Blackfire Polish and Rejex makes it look fantastic! However, a couple things that I don't like about Rejex: 1) it didn't seem as easy to remove as other waxes I've used before. Perhaps this is a function of it being a paint sealant, I don't know; and 2) the strong smell. Wow. If you're sensitive to petroleum products then this is not for you. I am not sure that I want to use it again because of the smell.
Former Vendor
I have a friend locally using Rejex and the other day after a wash we used Optimums Quick Detailer/Gloss Enhancing Spray and he swore it added even more gloss. Just a thought as I know you were looking for some additonal options too.
I suspect that you're right about the evenness of the Rejex application. I really tried to put on a small amount but I couldn't seem to spread it evenly. I used a cheap microfiber applicator so that may be the culprit.
Re: the quick detailer. I thought that the recommendation on the Rejex bottle was not to apply anything over it as it might interfere with the sealant? Perhaps I misunderstood that. So, quick detailers are ok?
Just wait a day or so before putting anything else on it. You will find it shines even brighter about a week later after a wash and an application of a quick detailer/wax.
Former Vendor
A quick detailer spray or gloss spray should not harm a well cured sealant like Rejex. Sometimes spray waxes and spray sealants might. As with anything you gotta try and try till you find your best combo.
