Question about Pinnacle application
Quick question for all you car care gurus out there. I've been using Zaino for the past year or so with pretty good results but I wanted to try something new so I picked up the Pinnacle Liquid Souvereign car care kit. My question is this, should I use the pre-wax cleaner that came with the Pinnacle kit to remove the existing Zaino or can I just apply the wax over the Zaino that's already on the car?
Danke Schoen!
ScottyJ
Danke Schoen!
ScottyJ
Re: Question about Pinnacle application (scottyj33)
You can apply the wax right over Zaino. Personally, I think the Pinnacle Paintwork Cleansing Lotion is absolutely fantastic stuff, and I would highly recommend using that first, then applying the wax. It leaves a smooth surface that the Pinnacle wax will spread over like butter. Try it and see. :D
Re: Question about Pinnacle application (DsC5)
Thanks for the advice DsC5. I'm gonna store the vette for the winter pretty soon, so I'm wondering if leaving the existing wax on would be good for protection (more coats of wax should equal less bad stuff can get to the paint in the winter...right?)
Thanks,
ScottyJ
Thanks,
ScottyJ
Thanks,
ScottyJ
Thanks,
ScottyJ
If you're driving it outside and looking for protection, I would suggest something like Zaino, it is much more durable than carnauba waxes.
St. Jude Donor '04 & '05
Grass is always greener on the other side. Just stick with the Zanio.
And you'll be fine.
tony
:flag
And you'll be fine.
tony
:flag
Re: Question about Pinnacle application (oldace84)
And you'll be fine.
tony
:flag
And you'll be fine.
tony
:flag
As for your question. Pinnacle paintwork is not very strong or abrasive , if you really want to make sure Zaino is gone try denatured alcohol prior. As said above, you can however add over Zaino and still get great results. I recently saw a chemical by Einzett? that removes synthetic/acrylic sealants, maybe at Detailers Paradise.
And you'll be fine.
tony
:flag
And you'll be fine.
tony
:flag
BTW...what did you not like about Pinnacle Souveran? I am assuming you have tried it in order to make your comparison...
