Cooling Problem
Received 8,928 Likes
Cooling Problem
After my last event at Watkins Glen I noticed my coolant temps are running high even with the Ron Davis radiator. The first day of the event somebody drove around the track leaking oil for a few laps. By the time the track workers noticed he had oiled down 60% of the track. It took them 120 bags of Speedy Dry to get the oil cleaned up. Of course I got a chance to run through the stuff which was flying around enough I had to close the face shield on my helmet to keep breathing. Once I noticed the cooling problem put the car up on the lift. The AC condensor is partially plugged (about 40%) with Speedy Dry so the air flow through the radiator is being limited. On Sunday I was at an autocross in 95+ heat and could not get the coolant to drop below 224 even when I turned the AC on. The fans would go into high speed mode but after a couple of minutes the AC would cut off. I took the car for a short drive at about 30 mph in 5th gear but it still wouldn't cool down.
Anybody know how I can get that stuff out of the AC condensor without removing the radiator and blowing air in from the back side?
Bill
Bill
Good Luck Bill
try taking the top of the radiator shoud off, then get a long thin wand and attach to a high pressure air hose. I do this frequetly to blow the crap out
I have also taken a baby bottle brush and attached it to a wire coat hanger then moved the bush up and down between the radiator and AC condensor.
Bill stick your shop vac in front of the condenser, then use an electric leaf blower or air nozzle on a compressor to blow between the AC condenser and radiator.
A good blast with a hose might do the trick also.
Two good ideas. I will start with the Shop Vac. That is one I should have thought of.
Bill
Bill
Bill just watch water pressure on fins they bend easy with hig pressure. Cleaning heavy equipment I hit a rad once and flatten them.
