Power Steerin Cooler Advice Needed
Old 08-26-2007, 11:40 AM
rikhek
rikhek's Avatar
Default Power Steering Cooler Advice Needed
My car is a coupe with no cooler. I have an issue with boiling fluid during track use. If I add the Z06 cooler would this be adequate? I see some guys adding a larger cooler for an automatic tranny. Would prefer the Z06 cooler for ease of installation.
You thoughts?
Rick
Old 08-26-2007, 12:08 PM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
The OE power steering cooler will be fine, but you do need one. I fried my PS on my 89 2x before I got one and that was the end of it.
Old 08-26-2007, 08:18 PM
JVetthead
JVetthead's Avatar
I did the z06 p/s cooler swap.. Easy bolt on, and no more puking p/s fluid.
To Power Steerin Cooler Advice Needed
Quick Reply: Power Steerin Cooler Advice Needed
