Track Rubber on Paint
Old 10-07-2007, 07:22 AM
RUN4CVR
RUN4CVR's Avatar
Default Track Rubber on Paint
Are there any secret tips for getting those nice black streaks of rubber off the paint the day after a track event? Its almost like they are permanent, very stubborn.
Old 10-07-2007, 07:30 AM
AU N EGL
AU N EGL's Avatar
There are several products.
I use 3M Trim Adhesive remover. Some ppl use WD30.
Old 10-07-2007, 07:34 AM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
I have used Zaino and it takes it right off
Old 10-07-2007, 07:57 AM
RUN4CVR
RUN4CVR's Avatar
Zaino wax?
Old 10-07-2007, 08:52 AM
elh0102
elh0102's Avatar
Most any wax should take it off. If not, WD-40, then wax.
Old 10-07-2007, 10:49 AM
WNeal
WNeal's Avatar
"Slower Azz Dog"
Originally Posted by RUN4CVR
Zaino wax?
Old 10-07-2007, 10:57 AM
wallyman424
wallyman424's Avatar
nah, the real magic stuff is quickshine 99. i saw jody using that stuff, MAN does it work. and we all know his racecar is the shiniest thing on track.
Old 10-07-2007, 11:22 AM
Falcon
Falcon's Avatar
Yep, Wallyman is right. That QuickShine 99 is the ticket. It gets rid of the rubber and other stuff immediately and shines the car at the same time.
Old 10-07-2007, 11:30 AM
Gatorac
Gatorac's Avatar
Pick up some wax and grease remover from the automotive paint store. A gallon of the stuff cost less then $20. Takes the rubber off with no rubbing and won't harm the finish.
WD-40 will take the rubber off but it's a mess to clean up.
Old 10-07-2007, 12:11 PM
RUN4CVR
RUN4CVR's Avatar
Available a your local auto store????
Don't think I've seen it before, but i'll give it a shot. Thanks.
Old 10-07-2007, 01:33 PM
davidfarmer
davidfarmer's Avatar
brake cleaner, wd40, bug/tar remover, even brake fluid...just take it off IMMEDIATELY!
Old 10-07-2007, 01:39 PM
Last C5
Last C5's Avatar
Stoners, the people that make the glass cleaner, makes a product called Tarminator. Spray it on and wipe the rubber marks off, that easy.
Old 10-07-2007, 03:43 PM
C5 XTC
C5 XTC's Avatar
Stoners Tarminator works like a charm; absolutely no effort. I use it after every track event. C5 XTC
Old 10-07-2007, 04:32 PM
2K3Z06
2K3Z06's Avatar
Location: KADS- If it has wings or an engine, I can break it. Dallas TX
Put some zaino on the hood, nose and roof, BEFORE you take the track. And it will come off with soap and water......
Old 10-07-2007, 07:27 PM
Geoff17
Geoff17's Avatar
I started a thread on this a while ago. There were a lot of posts and I tried most of the stuff. Most of it was just plan hard work and extra buffing and then waxing etc. Other stuff just plain did not work.
You are not going to believe this but by accident I found the perfect product. it goes on completely easily and effortlessly removes the rubber with no waxing, rubbing, etc needed.
In my basement I found an old, rusting can of GM Goodwrench Tar and Road Oil Remover Part #1050172. This was left over from my waxer days. I could not believe how great this stuff is.
I don't know if they still make it-this product alone may be responsible for global warming or cancer but it it is unbelievable at removing the rubber marks.
Geoff
Old 10-07-2007, 07:32 PM
heavychevy
heavychevy's Avatar
I dont know how many of the posts above do not damage the paint, but the my best (and fastest) way is to use a cleaner wax (meguiar or mothers is fine) and a PC or rotary, you can wax the whole car and take the rubber with it. But I detail my car carefully after every event. I then use optimum polish and P21S or pinnacle sovereign and I'm done. But cleaner wax on a buffer works great, and fast. Because I dont know about anyone else but I seem to get hundreds of them every time.
Old 10-07-2007, 08:50 PM
outnumbered
outnumbered's Avatar
To Track Rubber on Paint
Old 10-07-2007, 09:18 PM
ZO SIC
ZO SIC's Avatar
I had somehow got hundreds if not thousands of road tar spots on the pass side of my '06 GMC 2500HD crew cab... it is white and looked horrible. My usual mode was to use Meguirs Paint Cleaner. That was NOT working very well and taking forever...
The guys at the local Kragen recomended Tarminator (by Stoners) and it was PERFECT. Spray it on, wait, rinse and nearly done. Reapply, and then rub the most stubborn of spots. If there was any wax already on the truck this may not have been neccessary, and if there was wax I'm sure this stuff would remove it too.
$6 a can and I used 3 full cans.
Old 10-08-2007, 01:41 AM
rustyguns
rustyguns's Avatar
automotive PAINT store. big difference!
Old 10-08-2007, 01:42 AM
rustyguns
rustyguns's Avatar
Geoff
its called kerosene
Quick Reply: Track Rubber on Paint
