Z51 Brake Pad Question
I'm trying to decide what I want to do with choosing brake pads for track use. I've been running the stock Z51 pads and have been happy with them so far. I track at WSIR and, for those who haven't been there, it is not a heavy brake use track. 2 or 3 hard but short brake zones and a couple "taps".
I used a set of HP Plus pads on my 3,900# TA for a whole year running on Kumhos (8 - 10 days).
I have 4 full days (5 - 25 minutes sessions per day) on the Z51 pads and Z51 Goodyears so far this fall but am switching to an R compound tire for my next event and figure I should look at my brake pad selection.
I was looking at the DTC-70s but dang those things are expensive! I'm not sure I really need those at WSIR. So, now I'm wondering if the HP Pluses might fit the bill at considerably less expense.
I guess my question is if the HP Pluses are an improvement over OEM Z51 pads?
TIA
Paul
TIA
Paul
St. Jude Donor '07
l
l
Maybe try Carbotech 10's in the front and 8s in the rear??
Paul
I want your braking style, or an easier track on brakes, I guess. I've always had PFC 01 compound pads at Thunderhill. About 5 hours of track time and the front pads are done. '06 C6 Z51. I get roughly the same pad wear with Supercars or Toyo R888s. The three heaviest braking zones at Thunderhill (T10, T14, T1) are all pretty close together which may have something to do with it...
Here's a recent sample to give you some idea, nothing to brag about but fun :
http://www.youtube.com/watch?v=ywDXrRhLF30
TIA
Paul
TIA
Paul
i run khumo v710 slicks i just got some PFC01's and will run those in a month or so after these wear out. last event i had the Z51 on the back and the hawk hp plus on the front and that combination with my slicks was excellent! !!!! and cost effective
good luck! and Haul *** !!!
