c5 z06 wheels vs. c6 z06 wheels
Old 10-27-2008, 11:00 AM
alavette
alavette's Avatar
Default c5 z06 wheels vs. c6 z06 wheels
Can c5 z06 rear wheels be used in place of c6 z06 wheels. Wanting to change from the 19'x12" rears to 18"x12" rears. Cannot seem to find clear answer. Are the offsets different?? Is there an interference problem?
Old 10-27-2008, 09:02 PM
subtlez28
subtlez28's Avatar
Aren't C5 Z06 wheels 18x10.5" on the rear?
Old 10-27-2008, 09:24 PM
froggy47
froggy47's Avatar
yes
Old 10-28-2008, 03:31 PM
alavette
alavette's Avatar
Thanks that is what I needed to know!
Old 10-28-2008, 04:26 PM
exracer28
exracer28's Avatar
There are plenty of used 18x12 wheels for sale. I just bought some CCW with tires for my C6Z06. all for wel under $1k. Are you coming to Huntsville this weekend?
Old 10-28-2008, 10:42 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I use 18x10.5's all around on a C6Z06 for track tires. They sit inside the fenders quite a bit, so they look goofy, but they are inexpensive and work well. Clearance is tight on the front, not a problem on the rear.
Old 10-29-2008, 09:32 AM
alavette
alavette's Avatar
Yes I will be at the Hunts Auto X this week end. I have looked at some 18 x12 CCW's, all of them that I have found have the wrong offset,1.5" difference between OEM. I am worry about contact between tire and fender??? If you know of any out there that have the proper offset please let me know.
To c5 z06 wheels vs. c6 z06 wheels
Quick Reply: c5 z06 wheels vs. c6 z06 wheels
