racing tires and stock brakes
I've read a few post that stated it is a NO NO to use stock pads and rotors on a C6Z06 with a track tire such as Hoosier R6's. It has been stated to use a BBK. Can anyone explain why, thanks in advance
you can use the stock brakes for sure. just not the stock pads. with R6's youve got a whole hell of a lot more grip and you need an appropriate pad to deal with that.
stockers will probably fade into oblivion within a lap or two.
Lots of guys use the Stock PBR C6Z06 brakes with Hoosiers. Not stock pads though
Hawk DTC-70 front and DTC-60 rear or another option are the Carbotech XP-12 front and XP10 rear. There is a Cobalt single pad option as well.
and not all BBKs are the same nor stop better. Most BBKs are there to help equipment last longer, not always stop better. In some cases they do stop better, but not always.
the OTHER option is to change your driving style. Brake a little sooner, and carry more momentum though the corners. Many times this is better then Mash the gas then stomp on the brake peddle,
As AU N EGL said you can adapt your driving style to manage your equipment. It can be pads, tires, cooling or any number of conditions that require watching.
Making sure that I got this right. Stock caliper OK, Cobalt GTS single pads OK with OEM rotors, DBA 4000 or coleman rotors OK all with R6 tires OK. Just stay away from stock pads
just playing the devils advocate here.
My intention is to use street tires for the street and hoosier R6's for the track. I just wanted to check in with you guys first about the pad, rotor and tire combination for the track. I've been using street tires,oem pads and rotors at HPDE's.
Odds are if you are ready to move to R6 compound for a tire, then your are also ready to step up the compound of brake pad you use which will improve your tracking sessions. I agree that stock pads arent able to stand up to the added traction of the new tire. I think they are good for the street and beginning HPDE drivers, but once you start learning car craft and improve your driving skills, the consumables can also be improved.
Corvettes eat drilled rotors. They're really a cosmetic item and won't hold up at the track. H*ll, I even cracked a rear drilled rotor.
Tires and brakes are really two separate upgrades. You can do both at the same time, or you can do one at a time. It all depends on how much money you have to spend.
btw - If you have a problem with brake dust on your wheels you won't be happy with race pads. I know that's silly but you would be surprised how many people get upset with brake dust at HPDEs. Go figure.
Richard Newton
Ultimate Garage Handbook
Richard Newton
what is the difference of coefficient of fiction between hoosier R6's and michelin PS2 or goodyear emt's and how does it effect the stock brakes
(1.15-.95)/.95 or 21% greater braking force that is possible if the brakes are utilized at max efficiency. The greater braking force, the greater energy created in the braking system, hence greater heat generated by the pads thru friction, hence greater likelihood of brake fade with stock pads as you exceed their thermal design limits. The racing pads will have a higher operating temperature and a higher coefficient of friction to develop even greater braking force.
OK, here's what I have gleaned after talking to a lot of people, and doing a few hpde's myself. Definitely want upgraded brakes when moving to r6's. Problem is, stock rotors will crack and possibly break when you go to high friction pads. Left front rotor is especially suspect as the cooling veins are turning the wrong way. GM thought they could just flip right front rotor over and use on left wheel, but that puts everything backwards. A broken rotor can throw the car completely off the track and into who knows what. I wouldn't recommend running without new rotors if you are going to better pads. For what its worth. Jerry
