Would like to start attending track days but ....
I have a C5 convertible, and I am told that in order to particiapte I need a roll bar. True? If so who make one for a vert that will still allow use of the top?
TIA
Len
TIA
Len
I run a convertible. Most groups only require a rollbar in their advanced run groups. You can start out without the bar.
When you progress to the point that you need a rollbar, there are only a few options. Do a search on here and you'll find several threads.
I have a bolt in rollbar from Wolfe Racecraft in Fort Worth TX. Look up their website. It works great for me but it does have all the shortcomings you'll read about in the other posts (i.e., it rubs the stock seats and is closer to my head than most would like). It's nothing a fixed back race seat can not correct.
Again, don't worry about it now. Just go and have fun!
John
John
I'm not 100% sure, but I think in order to get the roll bar the right height, your top won't go up over it. It would have to be pretty low. The roll bar would have to be welded in also. Really the only way I see it, is buy another Corvette with a roof. The Organizers that let convertibles on the track only care about taking your money. Don't be foolish. I want you to go to the track. But a little safety would be better.
Steve
Steve
I can tell you proautosports and nasa here both just require the top up for HPDE 1-4. I believe SCCAs street program here is the same way. I know this for a fact, since a friend of mine runs in them..
JohnD has a good bar in his car. I have been looking for a good bar for my wife's car for a while now, and there isn't one. It'll be a custom job. You can start without one, but if you get fast, tracks and schools will require one.
CI 4-5-6-7 Veteran
I tracked a vert for a couple of years.
Wolfe Racecraft makes a roll bar that fits and lets the top work.
Clubs continue to increase the restrictions on verts even with roll bars. And every club and every track has their own rules. Most of which boil down to: "Go ahead and pay up front, and we'll take a look at your car when you get here and decide if you'll be able to run."
Take my advice, sell the vert and get a C5Z. You'll be money and hours upon hours upon hours of aggravation ahead.
That is excellent advice, a C5Z is the best track car for the money there is, and right now they are priced right. A friend of mine saw an 03 go through the auction with 15m miles on it for 20m.... If i had been there i would have bought it to sell later...
Anyone who would run a convertible without a roll bar in NASA HPDE4 is a lot crazier than I am!
MOST HPDE Clubs REQUIRE A roll bar for convertibles. and the roll bar must be AT LEAST 2" ABOVE the drivers helmet. Plus have FIA padding on the roll bar.
Roll bar must be a 4 point bolted to the frame. Swing out door bars are frowned upon as they are not really as safe as ppl think.
Most likely your top will not go up, unless you are 5' 6" or less.
Getting the roll bar that is SCCA Solo I approved is also a trick. The popular bolt in roll bars dont always pass the tech inspection.
Well thats not what I wanted to hear. I have no intention of going "wheel to wheel". I just want to play with my car a bit. I am not willing to trade going topless for going to a couple of track days a year.
I looked into MVP track time and they said I need the rollbar.
Do I have any other options? Again I am very new to all of this.
Thanks for the replies!
My roll bar is bolt in. The top will not function with it installed. It bolts in directly to the frame rails, and I spent a considerable amount of time and effort custom designing it to make it nearly factory looking when the roll bar is out, but allowing complete safety in the event of a roll over, as well as meeting the 2" above helmet rule, and I'm 6'8" tall.
My answer to you is this; you will probably need a professional builder to make you a bar, as any of the pre-built Wolf type bars are normally not high enough and the bars are too close to your helmet.
I see you live in Schuamburg Illinois. Autobaun Country Club http://www.autobahncountryclub.net/ does allow its members to drive in thier "B" group with a vert and no roll bar. IIRC Check their rules.
Still do not recommend driving on track in a vert without a roll bar.
But to become a member, may cost more then installing a roll bar and buying a hard top.
track is located
South Patterson in Joliet Ill.
track is located
track is located
track is located
To be quite honest, I think a lot of people overreact to this. For instance, go hang out at the Tail of the Dragon and you will see lots of people bombing through 2 lane public roads with no roll bars. You don't see people telling them they're crazy. Running in a track event with a convertible is as dangerous as YOU make it.
Our group allows convertibles without roll bars, but we highly recommend you get one if you are going to keep doing track days. It's easy to go at your own pace and take it easy when you are starting out. As you get more into it, you will start to push it harder, and at this point you need some more protection. We also run at slower tracks without high speed esses and the like.
If you are interested, send me a note or look for 3 ***** Racing events. We run at Gingerman, Grattan, and Waterford in Michigan.
Ken
