??? About C6 Stock Brake calipers / not Z06
Old 01-04-2009, 09:37 PM
geerookie
geerookie's Avatar
Default ??? About C6 Stock Brake calipers / not Z06
I heard, read, found somewhere that the C6 stock calipers are stronger/stiffer than the C5 stock calipers.
Does anyone know if this is true?
Do you have a link to the info?
Old 01-05-2009, 07:24 PM
geerookie
geerookie's Avatar
Anyone?
Old 01-05-2009, 08:44 PM
WBHighwind
WBHighwind's Avatar
From what I have read its not the caliper that is stronger, its the area around where the caliper bolts to the spindle on a C6 that is stronger.
Im sure somebody else will chime in with a more accurate answer.
Old 01-05-2009, 09:02 PM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
I heard that it is, that it's less likely to spread.
Old 01-05-2009, 11:12 PM
0corvette pilot
Former Vendor
corvette pilot's Avatar
the 2 calipers are virtually identical. The rears are the same and the fronts only differ cosmetically.
Old 01-06-2009, 05:42 PM
AU N EGL
AU N EGL's Avatar
Basically just different font for the lettering on the caliper
Old 01-06-2009, 06:06 PM
Aardwolf
Aardwolf's Avatar
The fronts been fortified a little, take a look:
Old 01-06-2009, 10:16 PM
geerookie
geerookie's Avatar
Thanks for the picture. It definetly looks like they have been strengthened a bit.
Old 01-22-2009, 11:03 AM
0corvette pilot
Former Vendor
Now take a look side by side with a C5 and you will see that it hasn't. The only difference are the fins on the C5 calipers and the font. Other than that, thicknesses are the same.
Old 01-22-2009, 12:49 PM
Aardwolf
Aardwolf's Avatar
I've been reading for some time on other forums about racers having the C6 caliper last longer then the C5 caliper. Here's a reference:
http://sccaforums.com/forums/6/282276/ShowThread.aspx
Mods, maybe merge these two threads on calipers.
Old 01-22-2009, 11:04 PM
abc 123
abc 123's Avatar
Yea, the thickness is the same, but the ribbing structure across the top has been addressed to help reduce spreading. GM/PBR would not change the main caliper casting just to enlarge the CORVETTE script on the front
Old 01-23-2009, 10:28 AM
ghoffman
ghoffman's Avatar
Cruise-In II Veteran
Is there a weight difference between the 2 castings?
To ??? About C6 Stock Brake calipers / not Z06
Quick Reply: ??? About C6 Stock Brake calipers / not Z06
