Open Lug Nuts
Old 02-02-2009, 11:04 AM
RUN4CVR
RUN4CVR's Avatar
Default Open Lug Nuts
Where can i get a set of open lug nuts for a C6 Z06...any recommendations from supporting vendors?
Old 02-02-2009, 11:09 AM
exracer28
exracer28's Avatar
NAPA carries them in stock. Ask for 2002 lug nuts
Old 02-02-2009, 11:15 AM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
I suggest you contact CCW. They're absolutely first rate in every respect.
Old 02-02-2009, 11:31 AM
c4cruiser
c4cruiser's Avatar
Just about any parts store will have open-ended lug nuts. The stud diameter, thread pitch, and the taper degree are the same for the C6 as for most any late GM car that had alloy wheels and metric studs. C5 and C4 cars use the same specs for lug nuts.
Old 02-02-2009, 11:36 AM
froggy47
froggy47's Avatar
Here's some. With threaded shank.
http://www.brandsport.com/grla-68038.html
Old 02-02-2009, 11:57 AM
Z06Fix
Z06Fix's Avatar
Just don't pick up the stock GM open ended lugs. I bought a set last year and I bet I didn't get three events out of them before they started rounding off
I will probly pick up a set from NAPA this year.
Old 02-02-2009, 12:49 PM
davidfarmer
davidfarmer's Avatar
ANY local Advance/Autozone should have them. They are usually behind the counter, not out with the fancy wheel accesories.
Old 02-02-2009, 03:42 PM
froggy47
froggy47's Avatar
I am surprised to hear that. I am currently using some gm ones that I bought when I started autox my LT4 and are now on the Z06, seventh season of autox, avg about 20 events a year & swap between 4 sets of rims/tires & same lug nuts. I gun them off & back on (easy). Finish with tq wrench. The threads are probably a bit over dimension now, but they keep the wheels on over 1g turns on A6 tires.
For high speed (track) I'd be tossing them by now, but low speed (autox say 80 - 90) they are still getting the job done.
I just last week ordered the ones I posted about earlier in the thread with the threaded shank.
A few more threads of engagement can't hurt.
Old 02-02-2009, 04:21 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,397 Likes on 749 Posts
Same here; I've been using the same set since '02 when we bought the car with no problems. If anything the aluminum flange/face (whatever you call the angled seat) on the wheels will see more wear.
Have a good one,
Mike
Old 02-02-2009, 05:04 PM
davidfarmer
I've only seen lugs and studs damaged by overtorquing or cross-threading.
Old 02-02-2009, 05:14 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Every time I put the car on jacks, I put my lugnuts in a bowl and spray them down with WD40. Seems to help prevent cross threading.
Old 02-02-2009, 05:33 PM
Z06Fix
Z06Fix's Avatar
I run mine off and on with a gun then finsh with a tq wrech as well. They are not rounding bad by any means but the socket is just a touch loose on them. I would love to have something that fits perfect and will take the abuse of an impact.
I have always added a touch of antiseize to the threads 2-3 times a season. Never had an issue with cross threading.
Old 02-02-2009, 05:57 PM
froggy47
froggy47's Avatar
I might wonder if you have a good fit between the nut & socket? I guess they do vary a mm or so from brand to brand.
Well at least they are cheap enough to toss & replace.
On my way out now to pull the wheels of my Z, corded the rears yesterday. I'll throw the street set on till the next event 2/15. My tire guy is on speed dial.
Be safe guys.
PS: I use anti seize also & torque to 95 rather than 100.
Old 02-02-2009, 06:33 PM
mikahb
Vetteless
mikahb's Avatar
St. Jude Donor '09
I found that removing torqued lugnuts with my rattlegun seemed to be hard on the threads. After changing out a boogered up front stud (thanks Jason for the tools and spare stud) at the track one time, I've stopped removing lugs that way. I now go around with a breaker bar and "un-torque" them all and then follow with the impact once they're loose. Takes only a few seconds longer and seems to keep the studs/lugs happier.
I got a full season out of this set of studs (GM Extended) and nuts (GM OEM open) with no issues. We typically remove and install tires at least 6 times during a normal weekend, so that's quite a bit of usage.
I'm changing everything out with ARP parts this year as preventative maintenance anyway.
YMMV
Old 02-03-2009, 11:12 PM
sperkins
sperkins's Avatar
I know longer racing studs are preferred, but what's the benefit of running an open end lug nut on the factory GM studs?
Old 02-04-2009, 08:22 AM
VetteDrmr
VetteDrmr's Avatar
It's not related to open/closed ended lugs, but all of the peanut/closed end lugs that I've come across are chrome-plated, which are the only lugnuts I've had problems with galling/breaking threads, which usually ends up killing the stud also.
Other than that I think they'd be the same as any other lug.
Have a good one,
Mike
Old 02-04-2009, 08:48 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
The fake chrome covers don't take well to impact guns. The closed end can get packed full of crud and prevent the nut from seating.
To Open Lug Nuts
Old 02-04-2009, 11:15 AM
froggy47
froggy47's Avatar
Also, there is the chance of a mis match in length between a lug & a closed lug nut. You torque it to spec & you think all is good, but you have really torqued the closed nut to bottom out & the wheel is loose on the hub.
Not probably but s##t happens, especially if a car has had more than one owner.
Old 02-13-2009, 08:40 PM
blackvetterzo6
blackvetterzo6's Avatar
Received 1,017 Likes on 566 Posts
I just ordered a torque stick. This seems to be pretty cool. They make them at all different torques and sizes. Hits 100ft lbs it breaks loose and your good to go.For the track i would think this would be great.
Old 02-14-2009, 03:29 AM
flink
flink's Avatar
The amount of thread engagement can be inspected by eye. (Plus the
other things people mentioned).
And they're lighter
Quick Reply: Open Lug Nuts
