C4 brake cooling
C4 brake cooling
I apologize if this has been covered but search isn't working for me today. I am working on getting my winter purchase ready for full time track duty. It is a 96 with Greenwood body parts. Has anybody found a good way to cool the brakes on these things? Honestly with the cold weather I'm in right now I am predicting possible problems and trying to fix them in advance rather than trying to react once a problem happens. Any previous experience or parts available are much appreciated.
The weather really needs to get warmer quick! I want to drive rather than buy parts that I may or may not even need!
I removed my turn signal assy and had a local heating shop build funnel shaped box that I mounted in the back of the opening. Hi temp tubing from the back of the box directly onto the rotor. Seems to work well.
You need to use spindle ducts, don't just route a hose toward the back of the rotor. I bought my spindle ducts from ZR1 MK, if you do a search you will see photos of this setup. I observed a reduction of rotor surface temperature(infrared pyrometer, not conclusive back to back tests) when I switched from enclosed Sawblades to 18" ZO6 wheels.
My air dam was damaged when I got my car so I replaced it with a new air dam that had build in ducts. If your air dam is in good shape, add in some NACA ducts. I would like to put on spindle ducts but haven't had time to make some yet. These ducts do help!
You could add NACA ducts to the nose as well, like this:
Thanks for the advice guys I suppose it wouldn't be hard to route the ducting like in your last pic. The problem that I am having is where to actually pull the air from. I would like to avoid cutting on body parts if at all possible. I suppose I could go from each side of the "mouth" and route the hosing from there.
redls1gto,
As I recall from earlier posts, your C4 is a dedicated track car. If so, you can replace the front parking lights with intake scoops and you will get all of the air you will need. With the body kit on the car, it is more difficult than just running ducts from the air dam across the bottom.
I used the headlight openings on my race car. In your case, if the headlights are functional, but not required for driving, you can convet them to air intakes. I have done that also. Looks a little funky, but the brakes will definitely stay cool. Can provide pictures if you are serious about going in either of these directions.
As you suggested, you can trap air in the cooling intake opening, but it will not be anywhere near the same volume and may not provide the solution you are looking for.
Ed
Ed
redls1gto,
Ed
Ed
Received 1,781 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I currently routed mine along the lower a-arm and it rubs when the tire is turned. I was wondering if having it up more it rubs or not.
Are my pix not working? It doesn't rub like how I have it shown on the LCA.
No they are working. I routed mine just like yours, but when I turn the wheel it pinches the hose about where it passes the sway bar link. I am also using 3" hose instead of 2.5", but the wheel come close to the hose. I am using 17x11 ZR1 style wheels, and my street wheels are 17x10.5 so maybe its the wider wheel.
Oval it just a little bit.
ZBRA has the same implementation I have, but a much cleaner execution. I did have ducts attached to the side turning light openings, but I was never convinced it produced a lot of air. They are now closed off, as well as the parking light openings. Front brakes are now fully cooled by dual NACA ducts in each of the headlight openings. I now have two 2.5" hoses to each front brake, which makes it a lot easier to route.
Ed
Ed
St. Jude Donor '07
MAD kit is OK, just toss the plastic hosing and get some hi-temp rated hosing.
On my C4 I ran my hosing through the suspension and it works fine. Added some extra duct tape for padding where it touches parts so it doesn't wear any holes in it. Used lots of wire ties to keep it in place. Works fine!
Alternatively you can go to many race shops and get the front air ducts and cut them into an existing air damn. All in all its not that expensive to do and a must if you run high speed events!
