(offical sales thread) DRM RTR, Let us build your dream car (dialup???)
Former Vendor
The DRM RTR project was introduced during a late night concept of Doug Rippie's. "We need to build a safe, light, fast, clean car and sell them to the track guys." My ears perked up. So sit back, grab a cold one and enjoy.
Body
Body fiberglass WC C6 Z06
Lexan front and rear windows
Carbon fiber wing
Splitter for increase front downforce
Both doors are fully operational
Front head lights (not DOT approved)
Rear brake lights
Painted to your favorite color
Two GM side mirrors
Chassis
Steel chassis with all unnecessary brackets removed
Full 10 point cage to meet most all sanctioning bodies rules
Nascar style door bars on both sides of the car
Steel firewall for safety
Z06 lightweight cradles front and rear
Chassis powder coated to your favorite color
Front and rear tubular bumpers
Jack posts for easier lifting
[IMG][/IMG]
Suspension
Mono-ball suspension bearings at all suspension to chassis points
Rod end steering arms for adjustable bump steer
GM power steering rack with a few trade tricks
Power steering cooler in the radiator
LGM Drop spindles
DRM Bilstein coilover shocks
Hyperco springs
T-1 swaybars with adjustable end links
Scaled, aligned and set ride height
[IMG][/IMG]
Brakes
AP front and rear brake package
Full race pads
14 inch rotor in the front
13.25 inch rotor in the rear
Titlton pedal assembly
Cockpit adjustable brake bias
SS lines to the calipers
Custom stainless steel hard lines
Frame style brake ducting
Spindle ducts
[IMG][/IMG]
Tire and wheel package
CCW race wheels
Hoosier R6 compound
295/30/30 front
335/30/18 rear
Engine
GM LS7 crate engine
Custom JE pistons
Katech rod bolts
Upgraded rocker arms
ARE Dry-sump tank and pan
Custom DRM Camshaft (630 horsepower)
Comp cams valvetrain
Aftermarket wiring harness
Modified computer program (pump gas)
Stainless steel headers
Rear exit exhaust
Race style mufflers
Ron Davis radiator with oil cooler
GM fuel tanks
Redline race oil
Drivetrain
Quarter Master race clutch
GM bellhousing
DRM flywheel shatter shield
Remote hydraulic bleeder
GM ZR1 transmission
GM ZR1 rear-end (3.42)
GM wheel bearings with ARP studs
GM ZR1 torque tube
GM CV joint axles
Transmission and differential coolers
Stainless steel Aeroquip lines and fittings
Redline fluids
Interior
Autometer gauge package
Kirban short throw shifter
Kirky driver and passenger seats
Collapsible steering shaft with removable wheel
Crow safety harness
Driver and Passenger window nets
Fire system (afff)
Body
Carbon fiber wing
Rear brake lights
Two GM side mirrors
Chassis
[IMG][/IMG]
Suspension
LGM Drop spindles
Hyperco springs
[IMG][/IMG]
Brakes
Full race pads
Spindle ducts
[IMG][/IMG]
CCW race wheels
Hoosier R6 compound
295/30/30 front
335/30/18 rear
Engine
GM LS7 crate engine
Custom JE pistons
Katech rod bolts
Rear exit exhaust
Race style mufflers
GM fuel tanks
Redline race oil
Drivetrain
GM bellhousing
GM ZR1 transmission
GM ZR1 torque tube
GM CV joint axles
Redline fluids
Interior
Crow safety harness
Fire system (afff)
Former Vendor
So here is the sales pitch. We would like to get rolling on #2. The price will be $150,000.00 No car needed for the build as we buy all brand new GM parts.
Payment of $75,000.00 required to get started on the project, 50,000.00 after the chassis comes back from powder coat. Final balance is due before the car leaves for the track. DRM will be assisting during the first time out with the car.
Email, call, pm for more info
Randy
www.dougrippie.com
763-477-9272
[IMG][/IMG]
Randy
www.dougrippie.com
763-477-9272
[IMG][/IMG]
Did you guys develop any parts for this car which will be available for general sale?
I appologize if this is thread hijacking,
Anyone know if these (specifically the front) fit on a C5 chassis? The pre-'08 steering rack has such terrible feel to it, I'd really love to be able to mount the newer rack on my car (and the weight savings is nice too).
I don't suppose you have a way to correct the above problem? If so, count me interested in a rebuilt steering rack that actually provides some feedback. I've got a solid mount (I made my own before you guys started offering one), but I think the problem is the rack itself.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Very very However, just a bit out of my price range!
Good luck building these they look like a work of art!
Well if I win the megamillions tomorrow I'll be giving you guys a call.
Where is that drool smile???
I have watched the build posts, and that is one fine machine !! With those engine specs, it should live for many a track day. Be still my 401 K balance, you need to stay put !! If I was able, I would be second in line - make mine gold with black frame -----
Former Vendor
I know the rear crandle is completely different. I'm about 95 percent sure the front one would be a pain in the butt to make work. I'm not 100 percent sure.
The racks are normally pretty good, we do a couple things to make they live longer and not have as many issues. We also have the ablity to change up the effort in the steering wheel.
Randy
Former Vendor
Former Vendor
It's been a long time since we had our coilovers on a skid pad. The last offical one was 1.1Gs with a 295-275 G-force street tire.
Randy
Former Vendor
Former Vendor
[QUOTE=Randy@DRM;1569903413]So here is the sales pitch. We would like to get rolling on #2. The price will be $150,000.00 No car needed for the build as we buy all brand new GM parts.
Randy
www.dougrippie.com
763-477-9272
Payment terms added to this post.
Randy
Randy
www.dougrippie.com
763-477-9272
Randy
Former Vendor
Here are a few of our past cars that we have built. Some pretty cool stuff! Some of them made it out with no pictures taken It sounds funny but when you live at the shop, it's kinda a normal thing. Other pictures are not in digital format.
Corvette Challenge
Lemans mid 90s
World challenge
More world challenge
One more C4
OK enough of the old stuff.
That should show you what our company can do for you!!!
Randy Rippie
Corvette Challenge
Lemans mid 90s
World challenge
One more C4
Randy Rippie
Former Vendor
