Aftermarket steering wheels
Old 09-29-2009, 04:51 PM
AlwaysInBoost
AlwaysInBoost's Avatar
Default Aftermarket steering wheels
I would like to see what everyone is running for aftermarket steering wheels. I've never been fond of the C5 interior, I've replaced the seats already and the wheel is next in line.
I have an idea of what I'm looking for... I want a D-shaped wheel that is 300mm or smaller diameter with a thick grip but would like to see as many pics as possible to makeup my mind.
TIA
Old 09-29-2009, 07:44 PM
flycastinguy
flycastinguy's Avatar
Me too. I've been looking at the offerings from Momo and Sparco, but most concerned about a nice looking clean fit on the C5 steering column. Not to hijack your thread, but I'd also like to know what others have done in that regard.
Old 09-30-2009, 01:16 AM
OKsweetrides
OKsweetrides's Avatar
Here's the style in mine, sorry I cant get any better pics. But it's a MOMO, red leather with some black in it to match the suede.
Old 09-30-2009, 08:49 AM
flycastinguy
Mike, is the plate on the front of your steering column part of a kit or did you have it fabricated? I assume mounting hardware may not be so make and model specific to provide that kind of trim piece.
Old 09-30-2009, 11:56 AM
HeyFred
HeyFred's Avatar
Here is mine. 03 Z06
ATI hub kit with MOMO wheel.
Old 09-30-2009, 12:04 PM
AlwaysInBoost
HeyFred, thats the wheel I want, we even have the same white HURST cue ball shifter.
which MOMO wheel is that
Old 09-30-2009, 12:18 PM
HeyFred
HeyFred's Avatar
Momo corse volanti
Old 09-30-2009, 12:20 PM
AlwaysInBoost
I'm curious; why did you go with the ATI hub instead of the MOMO hub?
Old 09-30-2009, 12:32 PM
HeyFred
HeyFred's Avatar
At the time, I did not know what I was getting into,so I bought the kit from ATI.
It included:
* Carbon cover plate w/ screws
* Hub and desired length of extention between hub and steering wheel.
I spoke with several people in regards to the MOMO hub. A slight modification had to be done to make it fit correctly on the C5. Plug and and play was what I was looking for.
Old 09-30-2009, 12:47 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I bought a 13.8" dia dished OMP wheel (momo pattern) years ago off an F355 Challenge car (it's wicked light). Used it on my old track car, but have not yet got a mount for it for the C5. It's on my list, I purchased a 2" sparco/momo pattern extension for it (the C5 seat/pedal/shifter/steering wheel alignment has never suited me, I want the wheel closer but nothing else).
i was leaning towards the ATI adapter...
Old 09-30-2009, 04:47 PM
GettReal
GettReal's Avatar
Where can you find the kit online?? Who carries that?
Old 09-30-2009, 06:27 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
What I will do this winter. Was it good any problems installing? I am looking for plug and play too.
Old 09-30-2009, 07:01 PM
HeyFred
HeyFred's Avatar
Install had no issues.
ATI Performance Engineering was who I purchased kit from, but they appear to be no longer in business.
Old 09-30-2009, 08:08 PM
MySR71
MySR71's Avatar
I was in their shop about a month ago so I think they are still around. If you want to contact them, my suggestion is to call Mike Akerly at 248-848-9200.
Old 09-30-2009, 09:02 PM
HeyFred
HeyFred's Avatar
Do they have a new site?
This one does not work.
http://www.accuratetechnologies.com/...aspx?tabid=118
Old 09-30-2009, 09:07 PM
MySR71
MySR71's Avatar
As far as I know, no, they don't have an updated web site.
Another option would be Pfadt's adapter for the C6:
http://www.pfadtracing.com/catalog/p...roducts_id/160
Then add somone's quick release (if desired) and steering wheel. Pfadt doesn't currently make one for the C5. I'm hoping they will sometime soon.
Old 09-30-2009, 09:52 PM
flycastinguy
Other suggestions anyone?
To Aftermarket steering wheels
Old 10-01-2009, 04:12 AM
trackboss
trackboss's Avatar
I have the ATI kit with a sparco wheel in mine. If ATI is no longer around you can still get the parts easily. The quick release is made by grant and then just search for a 3 bolt to 6 bolt adapter. What's nice about ATI is they make thier own adapter so it uses short bolts instead of long through bolts. They will make it in any length you want. I just got the standard one they offer, but I've since added a joes spacer. Had I known I wanted the wheel closer to me before the install I would have had them make a longer one.
Old 10-01-2009, 07:21 AM
AU N EGL
AU N EGL's Avatar
I have this one but it is not installed yet.
Went with the D style wheel so my knees dont hit the bottom of the wheel
290mm Description: Momo racing steering wheels for all racing requirements Material: Anticorodal aluminum, Suede Leather MOMO Formula
and other parts
http://www.ltbmotorsports.com/dilquicrelhu.html
I would suggest that the suede would be better then leather wrapped. Leather tends to get slippery
Imamotohead (03-23-2018)
Old 10-01-2009, 07:42 AM
CHJ In Virginia
CHJ In Virginia's Avatar
Be careful of what you change to if you also drive the car on the street. In a state that has annual safety inspectilons, you could be in trouble. Virginia will fail the car for removal of mandated federal safety equipment ( airbag ) on aftermarket wheels. Either find a friendly inspector or be prepared to swap back before the inspection.
Quick Reply: Aftermarket steering wheels
