VIR good to bed new pads??
Old 06-25-2010, 04:34 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Default VIR good to bed new pads??
Got new rotors and new pads. Carbotech says track only for bedding. Anyone successfully bed new pads at VIR?
Old 06-25-2010, 06:04 PM
C5inWV
C5inWV's Avatar
The bedding procedure is the same whether you're on a track or a road. I think Carbotech is just offering advice since bedding brakes on public roads may confuse other drivers or pedestrians.
I've seen people bed their brakes on the road at VIR betw the gate and the paddock. I don't know how VIR feels about this; it could lead to a discussion w/ officials.
I no longer sweat it w/ bedding pads. I'll go out in a normal session and bed the brakes. Come in early, stay out of traffic. There have been times I've gone from new pads to the grid to race w/o bedding and not had any trouble.
Old 06-25-2010, 06:15 PM
SouthernSon
I've had different results with different pads and just can't seem to find the ideal situation. I have roilled smoke out from Hawk, crumbled wilwoods into dust, smeared EBC and glazed a dozen rotors or more. I guess I'll have to run a few laps and see what happens, let them cool and see if the rotors are glazed. Of course, after the first fade I get to come in and listen for the new rotor to crack.
Old 06-25-2010, 06:24 PM
AU N EGL
AU N EGL's Avatar
Bed the pads tomorrow be for loading up.
really should bed pads Before you get to the track
Old 06-25-2010, 06:39 PM
PushinTheLimit
PushinTheLimit's Avatar
Doesn't Carbotech offer their pads now pre-bedded if you want them that way?
Old 06-25-2010, 07:43 PM
Kanmer
Kanmer's Avatar
Cruise-In VI Veteran
Prebedding is a falsehood. The object of bedding is to "embed" pad material into the rotors. How would any company sell you pre-bedded pads without your rotors?
Bob
Old 06-25-2010, 08:17 PM
sleeper02Z06
sleeper02Z06's Avatar
Art,
I've been racing on Carbs for 5 years now. What I have found is that all you really need to do with them is transfer a bit of pad material onto the rotor. This can easily be done on the first lap or 2. Just work the brake on and off for the lap to put some heat and material on them, then run the next lap or 2 without touching the brake for some cooling. You will be fine after that. More often than not I have actually gone out on new rotors and pads and the bedding process was the race, or pad transfer was done with 15-0 stops in the paddock ( away from everyone ) and still no issues.
Joe
Old 06-25-2010, 11:38 PM
Timz06
Timz06's Avatar
Bedding pads? I just put them on and haul ***.
Tim
Originally Posted by sleeper02Z06
Art,
Joe
Old 06-25-2010, 11:58 PM
sleeper02Z06
Tim
I was trying to be a little bit politically correct!! If you say you don't bed pads around some places you get dogpiled!
Joe
Old 06-26-2010, 12:33 AM
waddisme
waddisme's Avatar
Seems like the instructions that came with mine, I could do on the street. I wouldn't want to waste any track time bedding pads.
Old 06-26-2010, 02:27 AM
Short-Throw
Short-Throw's Avatar
Joe
Heck Joe, I've had to bed pads on the pace lap before Green Green Green. I'm sure you have to.
Old 06-26-2010, 07:11 AM
SouthernSon
Oakie Dokie! I am gonna run 'em hot for a few laps and then come in to let them cool and if they glaze over, smolder and crumble I will blame it on all my friends!
Old 06-26-2010, 08:34 AM
Kanmer
Kanmer's Avatar
Then you can just sit around and drink beer!
Bob
Old 06-26-2010, 08:50 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
rotors / pads will not last as long if you just go to the track and hammer them no matter how expensive they are. They need bedded the day before pads and rotors. Have I taken stuff out and hammered it yes but it cost you in the long run.
John Shiels
what wilwood pad did you crumble?
Old 06-26-2010, 03:19 PM
SouthernSon
A's ? I forget. Actually, my pad experience has not really been that consistent no matter the brand. I try to bed correctly. I have followed Hawk's recommendation of taping up the ducts and progressively slow from higher speeds. I have gone to fade with most pads and cooled at least 30, etc... Of course, cycling and down time between events might also contribute to the problem. yeah? and my rotors are from here and there, also. Well, I now see my problem; I need to be more consistent with procedure and discriminate with all equipment and keep records of experience better.
Old 06-26-2010, 04:20 PM
John Shiels
That A compound is really a street pad as I remember?
To VIR good to bed new pads??
Old 06-26-2010, 06:10 PM
Falcon
Falcon's Avatar
You know, I'm like you guys, I can't remember the last time I had time to bed brakes properly. I try some hard whoaaas on the pace lap and then it's haul ***, and hope like hell that the devil takes care of the details.
They'll sometimes have a good bit of vibration under hard braking the first lap or 2, but that goes away or maybe I don't notice it after that.
Old 06-26-2010, 06:42 PM
drivinhard
drivinhard's Avatar
"A" pad is still their highest temp/highest bite pad
things eat rotors like made, like a lathe
they work awesome though
one of those "these teams used X pad/caliper" posts that Gary H. posted last year still had a ton of Cup teams using the "A" pad.
Old 06-26-2010, 07:01 PM
John Shiels
I doubt he crumbled an A pad.
Quick Reply: VIR good to bed new pads??
