There are a few things I don't understand...
Old 07-18-2010, 06:14 PM
Falcon
Falcon's Avatar
Default There are a few things I don't understand...
1.) Einstein's Theory of Special Relativity
2.) Why anyone ever thought the derivative market was a good idea
...and last, but most importantly,
3.) Why in the hell GM didn't put access/cleanout panels on the radiator shrouds.
At times, I've been plagued with high coolant temps and it is nerve-racking racing with a car that requires backing off & short shifting to keep the coolant temps within tolerable levels to suit me.
A few weeks ago we took the radiator out and had it "boiled out' by a local radiator shop. It was full of debris, and sand up at the very top of the radiator where it meets the shroud and we can't reach it with a blow gun or other forms of cleaning it out.
Anyway, after the thing was "boiled out" and reinstalled, the coolant temps never exceeded 214* on a 104* day during 20 minute sessions. Needless to say, I was pleased, and figured if I kept it clean at the top, I could avoid these frustrations.
So, while sitting here at the palatial environs of the Big Pine Key Mobile Home & Adult Theme Park and drinking an adult beverage, I said, "Why the f*** don't I fix that. Hell, I made it though 8th grade shop class, it can't be that tough!"
After careful measuring, and checking, this is the solution I came up with, and should allow me to clean the top of the radiator cavity out easily and efficiently without removing the radiator.
Driver's side access panel:
Passenger side access panel:
Old 07-18-2010, 06:20 PM
Oyishdog
Oyishdog's Avatar
nice work!
Old 07-18-2010, 06:24 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Not only do I like the product, I especially like the marketing pitch!
Old 07-18-2010, 06:48 PM
Short-Throw
Short-Throw's Avatar
Very nice Jody!
I'm surprised you didn't use dzu screws!
Old 07-18-2010, 06:55 PM
JDIllon
JDIllon's Avatar
An easier solution would be to stay on track!!!! LOL!
Just kidding, I took mine out to get the engine out last week and I think I had most of the gravel in the parking lot at VIR in the radiator. Great idea Jody!!! JD
Note: that is the only complain I have about VIR! Those pits are a PIA!
Old 07-18-2010, 07:01 PM
Aardwolf
Aardwolf's Avatar
I especially enjoy making parts like that on my car.
Old 07-18-2010, 07:13 PM
eogel
eogel's Avatar
Hmmmm... Guess I'll have to find another strategy if I can't depend on you to back off occassionally to cool it off.
Ed
Old 07-18-2010, 07:16 PM
AU N EGL
AU N EGL's Avatar
Falcon has started making parts to fun his racing
Old 07-18-2010, 07:29 PM
Falcon
Falcon's Avatar
Originally Posted by Short-Throw
Very nice Jody!
Amazingly, as simple as these panels appear it was a relatively complicated to get it the way I wanted it.
The blank aluminium panel you see is attached through the shroud plastic (the shroud is sandwiched) into a piece of doubled sheet metal as a backing plate that has nuts welded to it so that the screws you see have a place to attach. Each of the screw holes are blind so we had to make sure the nuts would always be in the same place when the plates were reinstalled.
I thought of using dzu fasteners but they stick out pretty deep on the backside and I feared they might interfere/rub either the radiator or oil or transmission coolers. I erred to the side of safety.
It was also important to use a thick aluminium blank plate with stiff backing on the underside of the shroud so that no air could leak around the panels. We used a rubber gasket material on the aluminium plate to prevent air leakage.
This should accomplish all of those goals and be pretty easy to clean out with a garden hose or air.
This idea was one of the milder ones. You should have heard some of the crazy ones I had, but got talked out of. One involved a 5 gallon pressurized tank with a spray bar installed behind the shroud.
Thankfully, I've got a friend who is pretty smart and has a shop with a lot of tools and stuff, and he talked me out of that one, and helped me make this one.
Old 07-18-2010, 07:33 PM
Falcon
Falcon's Avatar
I tried that staying on track, and that didn't work worth a damn!
If you think VIR is bad, try CMP! The sand from that paddock was the main culprit of plugging up the fins on the radiator.
Old 07-18-2010, 10:44 PM
C5 XTC
C5 XTC's Avatar
Default Radiator
Great idea Jody.....when you gonna sell the plates, templates and installation instructions?????? C5 XTC
Old 07-18-2010, 10:55 PM
Short-Throw
Jody, if you don't have one yet, I'd like to take up a collection for your very first magnetic tip screwdriver.
Old 07-18-2010, 10:59 PM
davidfarmer
davidfarmer's Avatar
Jody will do even better than that...he'll come over in the paddock and drill a hole in your RADIATOR for you!
Old 07-18-2010, 11:03 PM
Racer-38
Racer-38's Avatar
Originally Posted by Falcon
1.)
Jody, You did this??? C'mon.............really?!
No errant holes in anything else I assume?
Old 07-18-2010, 11:48 PM
Greywolfe
Greywolfe's Avatar
Are you running the OEM radiator or something with more cooling capacity to get those temps?
I think I need to clean our my radiator also as my temps were much hotter on a stock C5Z at RA in June. I am also running staight water with some water wetter.
-Nasa SE DE3 guy that likes to watch the Falcon's vids!
Old 07-19-2010, 09:19 AM
Falcon
Falcon's Avatar
Yep, got a magnetic screwdriver and lots of extra screws.
Old 07-19-2010, 09:37 AM
Falcon
Falcon's Avatar
No, I run a Ron Davis racing radiator. Much larger capacity than stock. I run only distilled water and Water Wetter.
Yep, that's always a risk with me a power tools. I've been known to poke a few holes where they weren't intended!:o
I had a lot of help (I mean A LOT) from my buddy who is pretty handy with tools and stuff.
I don't think we punctured anything but I'll find out at R/A in August!
Old 07-19-2010, 10:26 AM
CHJ In Virginia
CHJ In Virginia's Avatar
Are you still running the AC condensor in front of the radiator or have you removed it ?? Could this design work for those of us that still use the cars as dual purpose street / track cars and still have the AC system ?? If you decide to market the design and templates, put me first in line. I swapped out my radiator to a DeWitts this last weekend. The amount of garbage, sand, etc. that was stuck in the AC condensor and old radiator was amazing. Even after a vacuum from the underside after the last event at VIR, I got at least two LARGE handfulls of garbage.
Old 07-19-2010, 11:02 AM
varkwso
varkwso's Avatar
Nice work. So whose mobile home did you source the metal from?
To There are a few things I don't understand...
Quick Reply: There are a few things I don't understand...
