Help me install my harnesses properly
Old 07-31-2010, 11:02 PM
0Superman09
Former Vendor
Superman09's Avatar
Default Help me install my harnesses properly
Okay, here is what I am working with. I could easily rig these up to "work" but what's the point of investing in safety equipment if it's not set up to do the job correctly?!?! So anyways, with the parts below I am working with, can you help inform me the best and proper way to install them?
Obviously the side lap belts are self explanatory, but should I use the top or bottom mount of the BK mounts for them?
The family jewels belts are where I am thrown for a loop. Really unsure where to route and mount these... I have 2 slots on the BK mounts but I don't think they are to be used for the crotch belts but what do I know? One of my belts as you can see is a clip in like the laps, and the other is a permanent mount. Can you guys help inform me where to clip in the one and where to mount the other so it works properly/best? Thanks!
RD Crossbar
Schroth belts attached to the Crossbar
BK lap mount kit
Rest of the Schroth hybrid 6 point harness
-Jon
Old 08-01-2010, 07:32 AM
AU N EGL
AU N EGL's Avatar
Shoulder harness go through the holes in the seat back
the sub belts come up between the seat bottom and seat back ( you sit on them.
Old 08-01-2010, 08:16 AM
0Superman09
Former Vendor
Superman09's Avatar
lol, just have those behind the seats for everyday driving so I don't look like a tool showing off harnesses
Ah, I understand the sub belts now! Any suggestions as to where to permanently mount the one? Thanks! And should I run it right back through where the seat bottom and back meet/recline?
Old 08-01-2010, 12:18 PM
AU N EGL
AU N EGL's Avatar
Hook them to the other mounting holes for the B-K seat belt harness mount
Old 08-01-2010, 09:39 PM
0Superman09
Former Vendor
Superman09's Avatar
one is a permanent mount... any suggestions for that guy? Thanks!
To Help me install my harnesses properly
Quick Reply: Help me install my harnesses properly
