Upgraded motor mounts for LT-1/4 engine?
Anybody know of any stiffer motor mounts - poly, etc. - for the late model C4 (92-96) with the LT-1/4 engine? Haven't been able to find a thing.
LT4 Solid Engine Mounts
Take a look at these:
http://s606.photobucket.com/albums/t...otor%20Mounts/
I never tried them on a car because they are not legal in NCCC Group 1 but we may get around to putting them on Joe's Group III car some day.
For what purpose are you using the car? I've also searched extensively to no avail. Quite frankly, the stock ones are pretty good, I still use them in the race car. In 8 years I've replaced them only once, and one of them wasn't torn but was looking pretty rough.
Solid is nice but not required. My fabricator quoted me about $60 a side to make a set IIRC.
It is a track dedicated car (road racing). I would like to reduce the movement of the engine on rapid acceleration/deceleration which can be quite a bit. Rather get that torque transferred to the ground plus the exhaust pipes are hitting the body.
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
It's a connection, usually a turnbuckle that can be adjusted, between the frame and the engine to limit movement.
http://www.ls1gto.com/forums/showthread.php?t=73996
http://www.fordmuscle.com/archives/2000/04/quicktips/
Are you sure you don't just need new ones? I don't have anywhere near that movement you're describing. And I do more than just drive my C4 to church on Sunday...
