C6Z06 brakes on a C5, what hoses to use
Old 08-28-2010, 04:44 PM
C5_Z06
C5_Z06's Avatar
Default C6Z06 brakes on a C5, what hoses to use
Can you use the stock C6Z06 brake lines (OEM rubber hoses) when installing the C6Z06 calipers on a C5? I know aftermarket stainless lines fit between C5/C6, how about OEM ones?
Old 08-28-2010, 11:37 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
To do the swap you need to use the C5 lines. The car end is different C5 vs C6. But the thread size and pitch is the same from 84-2011 on the caliper.
We just did a conversion in the shop using our C5 line kit
http://dougrippie.com/?p=434
These fit in a small flat rate box for ok shipping to you.
Randy
Old 08-29-2010, 04:15 AM
C5_Z06
C5_Z06's Avatar
Thanks Randy. Just out of curiosity, what's the difference on the car end? Threads and pitch?
Old 08-29-2010, 04:41 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
The flare is different. The C6 uses the same setup that the fords have been using for years. Why the change you may ask, I have no idea. The c6 lines require a male "olive" in the rubber-ss line.
Randy
To C6Z06 brakes on a C5, what hoses to use
Quick Reply: C6Z06 brakes on a C5, what hoses to use
