Question re: oil starvation - specific track
Old 05-29-2011, 04:17 PM
froggy47
froggy47's Avatar
Default Question re: oil starvation - specific track
http://www.speedventures.com/events/...il.aspx?id=351
I am going to run my 2004 c5z on this track which includes about 1/2 or a little more of the banked oval at Auto Club Speedway Fontana CA.
I'll have street tires & DOT R slicks available.
The speeds entering the banked section are about 80mph & if you have the grip & cajones are about 150 before you brake hard to get back to the infield road course.
Turning left CCW on the banks.
I'm guessing 15-20 seconds on the bank at speed.
I did 5 (passenger) sessions yesterday in an older pretty stock 911 & he was at 120 terminal velocity flat out & lower on the bank. The GT3's & GT3 cup were up a couple of lanes & doing about 25 or more faster.
Should I have any concerns re any oil pressure/foaming/pickup. Will run +1 qt.
Maybe a Hans?
Thanks, no guesses, please post if you have real (similar) data.
Old 05-29-2011, 04:28 PM
Z11409
Z11409's Avatar
Never a problem with either our C5 or C6 Z at Fontana.But as you spec'ed out 0ne quart over and at end of day check for oil in throtttle body.We run 1-2 lbs of extra air in right side tires.
Old 05-29-2011, 04:45 PM
froggy47
froggy47's Avatar
I don't have a catch can, do you just wipe out the excess? I have seen a little in the folds of the air bridge ahead of the throttle, when I autox.
Old 05-29-2011, 05:12 PM
AU N EGL
AU N EGL's Avatar
1-2 sec is more then enough time on any high speed sweeping left hander
Old 05-29-2011, 05:20 PM
froggy47
froggy47's Avatar
There were 3 or 4 c5z/c6z running yesterday. No blown engines. Maybe the banking helps compared to pulling G's in a more flat sweeper?
Old 05-29-2011, 05:50 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
we see almost 2 G's at Charlotte IIRC, through nascar 3/4 you're up there a long time. so far the engine hasn't minded, 24 degrees banking, about 153 mph entry and you don't have to slow very much
Old 05-29-2011, 08:05 PM
Z11409
Z11409's Avatar
Just wipe out with rag at the lunch break
Old 05-29-2011, 10:10 PM
wtknght1
wtknght1's Avatar
I've run Daytona, Homestead, Charlotte, Atlanta Motor Speedway, Pocono, Rockingham, and several other banked tracks and I never had any issues with the LS6. I just ran it at full...not 1 qt over.
Old 05-30-2011, 01:44 PM
froggy47
froggy47's Avatar
To Question re: oil starvation - specific track
Quick Reply: Question re: oil starvation - specific track
