Called LG today
Old 06-10-2011, 02:28 PM
johninar
johninar's Avatar
Default Called LG today
After reading so many threads that my head was spinning worse than the Bitch at Hallett, I ordered the G-Stop SL6 kit. Thanks to all the members out there that posted detailed, concrete experiences with their brake setups. I think this is really the best route for what I do with the car, and keeping the CFO happy (or at least tolerant) at the same time.
Old 06-10-2011, 05:04 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Great kit! Did you get thermolock pistons?
Old 06-10-2011, 05:31 PM
johninar
johninar's Avatar
Not yet, I'll be adding them later.
Budget is tight right now.
Old 06-10-2011, 06:54 PM
John Shiels
Still great setup. I like WW H pads.
Old 06-10-2011, 07:36 PM
johninar
johninar's Avatar
I did order H pads. good reviews on them for what it is.
Not a BBK but I think for an occasional weekend warrior this will work well.
Old 06-10-2011, 07:53 PM
CHJ In Virginia
CHJ In Virginia's Avatar
You are going to like the kit - probably the best bang for the buck out there. I have run mine for 2 years now and am very satisfied.
Old 06-10-2011, 08:42 PM
John Shiels
I never felt out braked by anything.
Old 06-23-2011, 05:15 PM
johninar
johninar's Avatar
I got a call today from LG. They are shipping my brakes today.
Question I have is how long did it take you guys to install them?
I'm using my stock rotors. I'm toying with the idea of installing them tomorrow night when I get to the track. Any gotchas I should know about?
crazy idea, should I wait till next week?
TIA,
John
Old 06-23-2011, 05:26 PM
sperkins
sperkins's Avatar
TIA,
John
Just make sure you carry a 12 point 7/16 deep well socket or you'll be putting your stock stuff back on.
Old 06-23-2011, 05:27 PM
John Shiels
I know you are dying to try them but rushes like that are rarely fun. I would wait and do them in a leisurely pace. No hard but you want to do it right and make should everything is aligned and tested.
Old 06-23-2011, 05:59 PM
gkmccready
gkmccready's Avatar
No gotchas. Just take lots of brake fluid since when you do the install they'll be dry... and, yeah, make sure you have all the new sized sockets you'll need to work on them...
Old 06-23-2011, 06:47 PM
OCCOMSRAZOR
OCCOMSRAZOR's Avatar
Based on John's recommendation I purchased the SL6's for the front and the SL4's for the rear.
These are an awesome brake setup and work very well during all of my racing this year. Use good pads and regularly bleed them and you WILL NOT be dissappointed.
BTW, with the correct tools, the install is actually quite easy.
Old 06-23-2011, 06:53 PM
SoDiezl350
SoDiezl350's Avatar
Thanks for the advice! I'm about to install a BBK as well. Do you mind telling me what part of the install that socket is needed for?
Old 06-23-2011, 08:40 PM
geerookie
geerookie's Avatar
Since you didn't get the T2 pistons I would recommend buying 4 of the titanium heat shields.
This place has the best price I have found. Most places get $100 for a set (4), these are $11.99ea.
http://www.speedwaymotors.com/Red-De...eld,29188.html
I run these and the T2 pistons so when you upgrade the pistons you will be in really good shape. I've never had brake problems.
Old 06-23-2011, 08:46 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
great price
looks like the backing plate for the old 7320 pad style (small bridge bolt hole) do you have to grind the ear off the top for the larger dia spacer used on the SL6/SL4?
Old 06-23-2011, 08:52 PM
geerookie
geerookie's Avatar
Originally Posted by drivinhard
great price
Yes....but it is only 1mm titanium most of your grinding wheel will be left
Old 06-23-2011, 08:54 PM
Falcon
Falcon's Avatar
Do these calipers work with 17" CCW classic wheels (T1) wheels?
Old 06-23-2011, 09:03 PM
geerookie
geerookie's Avatar
Yes. I think some people run a 1/4" spacer but I'm not sure it's needed.
These calipers have the narrowed front half. I run the full size ones but I hear you you need a 3/8" spacer for those.
The full size fit under z06 wheels with a 1/8" spacer and these don't need a spacer.
Old 06-23-2011, 11:30 PM
johninar
johninar's Avatar
Well my last question was academic as the shipment was not noted to hold for pickup as I asked it to be, so it will get to my house long after I've left town.
To Called LG today
Quick Reply: Called LG today
