Tire/Wheel question
Old 09-14-2011, 09:48 AM
MYRX
MYRX's Avatar
Default Tire/Wheel question
Can a Hoosier A6 size P315/30/ZR-18 be used on a rear OEM C5 Z06 wheel? I see that Hoosier recommends a rim width of 11" - 12" and I wasn't quite sure what the width of the OEM C5 18" wheels are.
Old 09-14-2011, 10:04 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
It'll fit.
Old 09-14-2011, 10:12 AM
RacePro Engineering
RacePro Engineering's Avatar
What do you hope to accomplish with A6es if you do not even know your rim widths?
Ed LoPresti
Old 09-14-2011, 10:28 AM
MYRX
MYRX's Avatar
Ed LoPresti
Get rid of the 275's I am already running
Old 09-14-2011, 03:12 PM
RDnomorecobra
RDnomorecobra's Avatar
stock c5z rears are 10.5" wide. that tire will fit but it's probably the biggest tire that would fit on a 10.5"
Old 09-14-2011, 04:20 PM
tjZ06
tjZ06's Avatar
Tons of us run 315/30-18 A6s on stock C5s wheels. They fit and work great. Here's my car on 295/35-17 front and 315/30-18 A6s on stock C5Z wheels:
-TJ
Old 09-14-2011, 04:36 PM
MYRX
MYRX's Avatar
TJZ06 Thank you for the pictures. The 295/35-17 front and 315/30-18 combination is exactly what I had in mind.
Thanks for all of the responses.
Old 09-14-2011, 05:17 PM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I agree, they will fit. 295/35-17 front and 315/30-18 is what I use also, but I use Rs on my track car.
To Tire/Wheel question
Quick Reply: Tire/Wheel question
