Newbie needs wheel/tire combo advice
Old 09-28-2011, 05:46 PM
taken19
Track Junky
taken19's Avatar
Default Newbie needs wheel/tire combo advice
Hey guys, I'm just getting into track events and I'm shopping for a spare set of wheels. I have a lead on C5 18x9.5 wagon wheels (set of 4) for a great price. My question is will having the same rims on all four corners present any problems with active handling, ABS or traction control? I plan on running in Comp mode for a while until I am more comfortable.
I want to make sure that these wheels will work on an 05 base C6 with Z51 package. Also, what size track tire will fit those rime and not present and challenges to the electronic nannies? I would like to focus on some of the scrubs that come up for sale here.
Any thoughts or advice?
Sean
Old 09-28-2011, 07:24 PM
mfquinn
mfquinn's Avatar
If your running square, you will need to shut everything off. Comp mode will complain. About a 1" difference on stock sizes between front and rear. On stock size wheels you can go with a 265/35x18 and 305/30x19 and comp mode will be okay. That will keep you close to that 1" difference
Old 09-28-2011, 07:27 PM
mfquinn
mfquinn's Avatar
But 19" rears are $xpensive and hard to find scrubs
Some run 18" all around but different diameters between front and rear. Better opportunity to find scrubs
Old 09-28-2011, 07:53 PM
Sidney004
Sidney004's Avatar
Thats going to limit you on tire size to a 275/35-18 or thereabouts.
Old 09-28-2011, 08:06 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
perfect tire (size) for banging around in HPDE, etc. lots of scrubs avail in that size, a zillion various cars run 'em
Old 09-28-2011, 08:10 PM
Pumba
Pumba's Avatar
Forget the 18 x 9.5 inch wheels.
Find a set of C5 18 x 10.5 rear wheels. Then you can mount the tire sizes you need.
Old 09-28-2011, 08:33 PM
taken19
Track Junky
taken19's Avatar
Will that combo still allow traction control and active handling? I guess I should do more research and stop being lazy....
Thanks for the input.
Old 09-29-2011, 06:29 PM
Pumba
Pumba's Avatar
You could mount the following tires on those rims:
Hoosier A6 or R6 285/30R18 front at 24.9 inches in diameter
Hoosier A6 or R6 315/30R18 rear at 25.6 inches in diameter
No Active Handling or Traction Control problems.
Old 09-29-2011, 08:39 PM
mfquinn
mfquinn's Avatar
If you are running brake cooling ducts with hoses, you may have an issue with the 285s on the front.
Just saying.....
Old 09-29-2011, 09:18 PM
taken19
Track Junky
taken19's Avatar
Just saying.....
Good info. Yes, I just put on brake cooling ducts a few weeks ago - good thought.
Thanks for the heads up.
Sean
To Newbie needs wheel/tire combo advice
Quick Reply: Newbie needs wheel/tire combo advice
