LG Motorsports G Stop 6 Piston Wilwood Brake Kit w/ Slotted Rotors & FREE SHIPPING!
Old 10-19-2011, 02:25 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Default LG Motorsports G Stop 6 Piston Wilwood Brake Kit w/ Slotted Rotors & FREE SHIPPING!
Kit w/ Slotted Rotors & FREE SHIPPING!-$1599
0% Financing for up to 1 Year Available on all LG Parts purchased from TPS!
Have you always wanted to improve your brakes BUT didn't want to get new wheels to fit the larger rotors? We have the solution for you.
LG Motorsports has done it again with their G Stop 6 Piston Brake System! Even fits most 17" wheels including the 17" C5 Z06 Wheels! This great package allows use of your factory C5/c6 front rotors.
As a SPECIAL BONUS we throw in a set of TPS Slotted Front Rotors absolutely free!
Package Includes
**Wilwood SL6 6 Piston - Full Width Calipers (Black)
**TPS Stainless front brake lines
**LG Motorsports brackets with hardware
**Package comes with your choice of Q or E pads
BRAKE PADS AVAILABLE
PolyMatrix E
Light to medium duty road racing and track day events.
Drag racing with iron or steel rotors.
Performance street category competition.
PolyMatrix Q
Disc brake conversions on street rods, muscle cars, custom show cars, and all moderate performance applications where low noise and dust are important.
PolyMatrix H
Great pad track use. Track use only as they are noisy
Here is a picture of the G-Stop Kit with cross drilled rotors (NOT INCLUDED)
__________________
TPSMotorsports.com
Mike Mak
2705 Lafayette Street
Santa Clara, CA 95050
Phone #: 408/898-4632
Email #: MikeM@TPSMotorsports.com
Authorized dealer of Corbeau Seats, ECS Superchargers, Edelbrock SuperChargers, A&A Superchargers, Kooks, Whipple, Magnalow, Corsa, Borla. LG Motorsports, Procharger, Billy Boat Exhaust, AWE Exhaust, American Racing, TPS Brake Rotors/ Kits, Stainless Steel Brake Lines & much more...
Old 10-19-2011, 03:37 PM
CHJ In Virginia
CHJ In Virginia's Avatar
That is a GREAT price on the G Stop kit. I paid more than that minus rotors and shipping for my kit 2 years ago. Bump for a good price.
Old 10-19-2011, 05:27 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Thanks! These are some of the best brakes you can get that will fit a 17" wheel
Old 10-19-2011, 06:22 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
A mod that pays for itself! I love mine.
Old 10-19-2011, 07:10 PM
travisnd
travisnd's Avatar
I bought a set of these used a few months back... worth every penny. I ran comp school and raced at VIR two weekend ago and was very happy to have them in place. The best part is the 20mm thick pads. I'd have gone through a set of OEM pads on Friday in Comp School alone. With the Wilwoods and Carbotech XP12 pads I still have over 1/2 the original pad thickness after four 40 minutes sessions in Comp School, 2 sprint races Saturday (25 minutes), and a one hour "fun race" on Sunday.
Old 10-20-2011, 11:19 AM
skyavonee
skyavonee's Avatar
Is it straightforward to move the stock front brakes to the rears while replacing the fronts with this set?
Old 10-20-2011, 12:37 PM
travisnd
travisnd's Avatar
If you want to remove your parking brake then yes... you just put the front rotor on the rear and bolt the caliper up.
However there's no need... it would mess up the brake bias and add rotational mass.
Old 10-20-2011, 01:40 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
If you do a search there are several threads of people doing this and it looks pretty cool.
Old 10-25-2011, 09:42 AM
JVetthead
JVetthead's Avatar
Does Carbotech make pads to fit these?
If so I might be interested
Old 10-25-2011, 10:10 AM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Yes we do
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 10-25-2011, 01:54 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Originally Posted by carbotech adam
Yes we do
There's your answer from Adam So you wanna order a set?
Old 10-30-2011, 12:41 PM
JVetthead
JVetthead's Avatar
Do you have any data comparing these to stock calipers such as clamping force, pad surface area, etc? Since they use stock size rotors I need to know if the results/cost is worth while..
ie; 10% more braking power would be great or would I have to go bigger to get that much. Also I run front calipers on the rear.
Joe
Old 10-30-2011, 02:06 PM
stevensa
stevensa's Avatar
How do these compare to the Hardbar/AP Racing setup? They are basically the same price.
Old 10-30-2011, 02:11 PM
gmccreary
gmccreary's Avatar
How much for just the calipers and mounting brackets?
Old 10-30-2011, 07:21 PM
John Shiels
Joe
pad surface is not the end all. Caliper stiffness is what they offer. Thicker pads last longer and wear more even so you end up saving money. Better than stock in the later laps. I doubt they stop better than a NEW set of OEM but they are better on track and worth the money. They are great for the price I had may be the first set from LGM. I have SL-4 WW on rear with 13 rotors on rear. You can modulate them better as they are more consistent in feel than a used spread OEM caliper. Thermo-lock pistons are a great addition. 7420 pad shape is arguably the most common pad around with tins of compound choices. I like H from WW I never tried A but never felt I needed the A.
Old 10-30-2011, 09:50 PM
jon6.0
jon6.0's Avatar
I've already got stainless lines and I don't need rotors. How much for just the calipers, brackets, and pads for a beginner on a road course?
Old 10-30-2011, 10:29 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Joe
I don't have any hard data regard the stock vs the LG BUT the stock stock has 2 piston calipers vs. the Wilwood's 6 piston calipers. The LG/Wilwood caliper is ALOT stiffer than the stock caliper.
Thanks for your feedback on the bracks.
The kit is available with the following 2 packages....
#1-Lines, pads, rotors, calipers, and brackets
OR
#2-Lines, pads, calipers, brackets, AND NO ROTORS.
OR
Your lines will not work with the Wilwood calipers as the have different ends.
I don't know much about the Hardbar/ AP setup BUT I don't think the AP/ Hardbar system can use stock rotors...If that is the case the LG/ Wilwood system is alot more cost effective.
To LG Motorsports G Stop 6 Piston Wilwood Brake Kit w/ Slotted Rotors & FREE SHIPPING!
Old 11-06-2011, 01:34 PM
TPSMak
Supporting Vendor
TPSMak's Avatar
St. Jude Donor '11
Sunday Bump... who else wants a set? Guaranteed smoking price
Old 11-06-2011, 01:40 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
It can
Old 11-06-2011, 02:10 PM
redtopz
redtopz's Avatar
Joe
I found them about the same as stock brakes, but they are more consistent and the pads and rotors last longer. Plus the pads are cheaper and won't taper as much. To balance front calipers/rotors in back you might want to go with a 14" rotor in front. You also might need a larger master cylinder to handle the extra piston displacement or your pedal might get long. At least that's how my ST2 car is setup.
Quick Reply: LG Motorsports G Stop 6 Piston Wilwood Brake Kit w/ Slotted Rotors & FREE SHIPPING!
