Castrol SRF brake fluid
Anyone else use it? My car is full of it and I'm told its the best to prevent fade. Is there any cheaper alternative or should I just keep with it. Stuffs pretty expensive but if its that good I'm fine with it.
I've used it exclusively for my track-only Z06. I've never had a problem with boiling fluid and use the car hard. I'm a believer.
Steve
Steve
I think SRF is the best fluid out there and it can not be beat. From What I understand racers who use it only bleed the caliper before an event then top off... If you are using the car monthly or more I think it is good... But I have had HPDE students in green group who do 2 events a year say they used SRF ... way overkill for that.
Former Vendor
Why is it the best? Highest wet boiling point of anything else out there. Very close to the highest dry boiling point.
About 3-4 years ago, there was a huge shortage of SRF in the US. The phone calls from top teams in every form of Motorsports started calling us. Nascar, indy, ALMS, grand am, sprint cars, drag racers, motorcycles, karting, and etc. They all use this stuff by the case.
Why do we sell it at a damn good price? Because we can't sell other things if your car is piled up in the tires at the end of the straight
http://dougrippie.com/?p=430
Randy
Randy
For me, it's easier (and cheaper) to just flush the whole system with ATE a few times a summer. I've never had an issue with boiling fluid doing it this way on my C5Z or LS2 GTO (big, heavy pig with small rotors running race pads).
I top off with the partial container. Brake fluid IS hygroscopic, meaning it absorbs moisture, but within a sealed container it can only absorb whatever moisture is in the container once you seal the cap back up.
The reason I don't worry about it is - my car has Tilton master cylinders for the brakes and the clutch and they are mounted right down by the pedals. There is a remote mounted fluid reservoir for the DOT4 fluid which feeds all 3 master cylinders as the fluid level moves down. Within this remote reservoir, there is air above the fluid and the cap is vented to atmosphere, so apparently my fluid is always absorbing moisture. Oh well, if the Tilton system is good enough for real race cars it is good enough for me (although some would probably say one needs to replace all the fluid in the system pretty regularly I suppose).
I will say I have never boiled the fluid yet.
What do you top it off with? Do you keep enough fluid in the bottle to bleed for the next few times or open a new $80 bottle and leave that on the shelf? Everyone always says that as soon as you open the bottle it's no good to save.
Where SRF really shines (at least compared to the Motul I also use) is that it allows you to skip bleeding at the track/after day 1 of a 2 day event. I found this to be true even on a track that was hard on brakes. At VIR, easy on brakes, the motul still needed a bleed after day 1.
Do you like working on the car, even on hot days? How much is your time/sweat worth to you???
In regards to topping it off... Never used the stuff my self ... I purge system fully before each monthly session ... use about 1/2 can of ATE which is about 7 bucks a bleed and puts me at about 100 bucks a year in fluid. I have never had a fluid problem at track with the speeds / pads I use... I had only spoken to people who used SRF and recall they said they bleed the calipers before an event and add additional fluid as needed not sure of shelf open life.
Received 8,930 Likes
I use the Ford fluid and Wilwood 570. Flush before each event unless they are only a week apart and then I just bleed the calipers. In 19 years I only boiled brake fluid once when I ran with a very thin set of pads.
Bill
Bill
Tolero Apto Victum
Randy
Randy
Thanks for the info.
Really expensive and we use it in the ST2 car because it came set up with it. Cannot really tell the difference from cheaper fluids used in my other cars.
