This is what happens when you get bored on a Sunday............
So this past Sunday I was bored and decided to work on my winter project. 8 1/2 hours later this is what I ended up with. The car is MUCH lighter than Mark's now
Some of my winter projects will include:
Relocating the ABS pump and EBCM inside the car to get the weight off the nose
Relocate the PCM etc. to inside the car
Flip the Rad forward
Install a QuarterMaster 7.25 8-leg Optimum-V clutch
Install 243 heads, 25% Underdrive ATI Damper, LS3 water pump and set Rev Limit to 6800rpm
Install ZR1 Spindle Uprights to reduce caliper mount flex
Relocate alternator
Install all new brake lines
Make front splitter removable to ease loading on the trailer
If my calculations are close I should have 50%/50% front to rear static and 51%/49% side to side weight distribution with no ballast and be at about 2955lbs with me in the car and 1/2 tank of gas when I'm done. This also includes a passenger seat.
Here's a picture of the ABS and PCM relocate. I haven't finished cleaning up the wiring yet but when I shortened all the wiring harnesses I removed about 6lbs.
I weighed my SPEC Clutch which has a special aluminum lightened pressure plate and a Fidanza aluminum flywheel, it was 31.5lbs. The new Quartermaster setup is supposed to be about 15lbs.
With all the work to relocate stuff and remove any extra weight I have pulled about another 55lbs off the nose of the car.
And some of the weight I had to keep up there I moved to the passenger side of the car.
Relocate alternator
impressive!
no headers this year?
Looks like you got mighty happy with a hole saw on that hood! Impressive stuff as always. What really makes me chuckle is that you're just now starting your "winter" projects when the SE guys are racing at CMP this weekend and us MA folks are at VIR next weekend
Our first event is a DE at Limerock at the end of March which I may use as a shakedown but more than likely will not be ready until the Friday test & tune April 20th which is out first race weekend.
Holy Smoke! G, you are one impressive guy! I think you'd tackle about anything!
The wife did come out and hold the nose of the car up high enough for me to roll the motor and suspension out from under the frame on the floor jack. It took awhile to find the right spot so everything would balance properly.
I will have some of that tomorrow as soon as the Brown truck arrives!
Did you buy it from Danny? QuarterMaster direct? Other?
Nevermind....I didn't see Danny's response...
The man from Cincinnati. That's what Quartermaster recommended I do. Just like all the other stories floating around here, Danny took the time out of his day to go over the various clutch options based off what I using it for. Once I decided, he got it to me quick, fast, and in a hurry.
