AStock legal? Slotted or drilled rotors
Old 03-03-2012, 03:28 PM
Alludc
Alludc's Avatar
Default AStock legal? Slotted or drilled rotors
if stock size rotors, would they be AStock scca autox legal if they were drilled or slotted? Im thinking no, but curious
Old 03-03-2012, 05:08 PM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
You are correct, you can't use those.... they must also be stock style rotors.
Old 03-03-2012, 05:31 PM
Alludc
Alludc's Avatar
figured. thanks
Old 03-03-2012, 09:00 PM
AverageVetteNut
I will say this though... if you're looking to just run local events, I'd talk to you other competitors. Personally I think it's not a big deal and locally if you ran against me, I'd not care.
while you always want to get in the habit of following the rules, if no one cares there, then that's no biggie.
good luck
Old 03-03-2012, 09:39 PM
Alludc
Alludc's Avatar
I'm running tours this year, that's why I checked
To AStock legal? Slotted or drilled rotors
Quick Reply: AStock legal? Slotted or drilled rotors
