How much time could I shave off between street tires and DOT slicks?
Old 04-04-2012, 09:34 AM
ninety4formula
ninety4formula's Avatar
Default How much time could I shave off between street tires and DOT slicks?
What is the time difference between say the XS or NT05 vs. an A6 or 710? I'm not really concerned with being able to drive them to the event. Last season I had nitto NT555 street tires on the front and Nitto Invos on the rear. Would I notice a difference even just going to one of the street tires mentioned or would it not be worth it?
Old 04-04-2012, 09:48 AM
1991Z07
1991Z07's Avatar
It depends on what you are running...
A the minimum you'll shave a few seconds off a short autocross course. When I went from street tires to DOT "slicks" I cut an average of 4 seconds off my times the previous year on a 45-50 second autocross.
You can estimate what you'll shave on a road course by timing cars of equal make/model/mods with slicks while they run. It'll give you a ballpark to shoot for when you change over.
Old 04-04-2012, 09:58 AM
AU N EGL
AU N EGL's Avatar
It depends . . .
more on car set up, suspension set up and driver skill, then just tires
Old 04-04-2012, 10:03 AM
ninety4formula
All I do is autocross. I can't imagine losing 4-5 seconds off a 45-50 second course. That would be sweet. That would put me in the running for FTD
Old 04-04-2012, 10:04 AM
ninety4formula
Originally Posted by AU N EGL
It depends . . .
I know there are other variables, but assuming it was the same setup, what do you think the time difference would be just from tire swaps between the tires listed above?
Old 04-04-2012, 10:47 AM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
2-4 seconds easy
Old 04-04-2012, 10:49 AM
The Panther
The Panther's Avatar
Stock C5 Coupe. Switched from NT555 (street tire) to NT-01 and cut ~6 seconds at Road Atlanta. Average driver at best.
Old 04-04-2012, 12:42 PM
AU N EGL
AU N EGL's Avatar
What lap times are you running at the Glen ??
From 4 to 10 secs quicker on VIR once you learn the new tires. AND you are on a fresh set of "A"s
Here are some NASA- NE time trial results
http://www.nasa-tt.com/Northeast_Regional_Results
This will give you ideas of times.
Track Records on NASA NE tracks
http://www.nasa-tt.com/Northeast_Track_Records
Old 04-04-2012, 12:52 PM
ninety4formula
I have never run up at the Glen, the only thing I have done is take their paced laps. I have done an autox in the paddock though and found a nice bump that made it so only one wheel was on the ground haha. That one didn't feel too good.
Old 04-04-2012, 12:56 PM
AU N EGL
AU N EGL's Avatar
Ok How long are your normal Auto-X sessions?
and how have you placed ?
Old 04-04-2012, 01:06 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Rule of thumb was 2sec on a 60sec course if I remember.
There are however a wide variety of thumbs.
Old 04-04-2012, 01:33 PM
ninety4formula
Our autox sessions vary depending on the lot or track we go to. They vary from 30 seconds to 1:20. When I race with the NCCC I do quite well. Last year I was very close to a 2010 WRX that had suspension mods, some stickier street tires, and some bolt ons. He ended up beating me, but over all I place in the top 10 consistantly I would say. My car was in BSP but my only mods were no cats or mufflers, a mail order tune, A.I.R. delete and small things. We have a good amount of SM and SSM cars though that have better suspension, brakes and tires so I think top 10 isn't too bad.
Old 04-04-2012, 01:49 PM
froggy47
froggy47's Avatar
4 sec on a 45 sec course is a stretch.
Old 04-04-2012, 01:52 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
there are lots of threads about this on various forums, and the speed (or time) pick up always varies. I think one of the reasons it varies is types of cars. high hp cars need forward bite to run good lap times (autox or road course) lower hp cars don't. So they basically only benefit through extra corner speed, and braking. High hp cars benefit from corner speed, braking, and exit grip. Another way to look at it, the % of time you are WOT won't change as much in a lower hp car from a good street tire, to a sticky R comp. It WILL change a bunch in a higher hp car, and thus it's relative time (tire to tire) is probably going to be much faster.
Old 04-04-2012, 01:53 PM
AU N EGL
AU N EGL's Avatar
so maybe 1 sec quicker per 30 sec of run
Old 04-04-2012, 02:02 PM
ninety4formula
I could believe 1 second. I know that my car has a tendency to push into corners (whether I don't have the traction or too high of a speed into the corner I'm not sure). It is funny when you try to explain this to people though that haven't done it before. When people hear 1 second and they count it out loud, it doesn't sound like much, but people that do this type of stuff know that a second is a lot. I've lost races by .00x's before. It sucks! Here is a pic of the autox at the Glen I was talking about earlier...
Old 04-04-2012, 02:10 PM
SteveC68
SteveC68's Avatar
http://grassrootsmotorsports.com/articles/measuring/
That is an article from 2010 that tries to answer your question. 1.3 seconds on a 44 second course.
To How much time could I shave off between street tires and DOT slicks?
Old 04-04-2012, 05:56 PM
ninety4formula
So if I read that correctly it is saying that there is a 1.8 second difference between the Kumho V710 and the Kumho XS on a 1 minute course. That is quite a bit. I thought I was going to get some 710's today but there was only one available....
Old 04-05-2012, 01:57 PM
Gordy M
Gordy M's Avatar
A lot depends on what type of course you are running (tight or loose) and what tires are you comparing them to. In the last two years I ran both hoosier A6 and Hankook RS3's autocrossing and was looking at my times. On a momentum type course--fast and wide-- I was consistently 2.3-2.8 seconds quicker per 60 seconds. In a tight, narrow, technical course, I was consistently 3.5 seconds slower. The A6's allowed me to go deeper before braking, corner at higher speeds and have higher exit speeds. On a fast momentum course, I was able to keep the Hankooks holding very well but I still did not have the braking power of the Hoosiers.
Old 04-05-2012, 02:46 PM
95jersey
95jersey's Avatar
There are other things to consider. When moving up to R compounds those street/dual purpose brake pads you probably have been using will become worthless, you will need dedicated race pads. Also, your brakes will now run significantly hotter, so add brake ducts. You will eat through rotors at 3X the rate you did on street tires. Also, you will eventually deform you rubber control arm bushing, wear out wheel bearings, and with all that grip, the stock suspension will roll over like a **** on prom night, so now sway bars or new springs/shocks eventually.
While it is fun as all hell, and I could never go back to street tires, that extra 4-6 seconds is going to cost you big $$$$.
Quick Reply: How much time could I shave off between street tires and DOT slicks?
