Power steering question
Old 05-21-2012, 11:11 AM
spazegun2213
spazegun2213's Avatar
Default Power steering question
So I installed a z51 PS cooler on my race car years ago, and this weekend when I went to remove it to remove the rack, the damn thing would not come out. I ended up rounding off the fitting while using a set of flare nut wrenches. So I just cut the damn thing off and presto! However, I'm now left without a fitting to attach the line to the rack. My question to you guru's is do you know what fitting it is? size, thread pitch etc? I'm thinking about buying a new fitting and having some place local install it and flare the hose again.
TIA
Old 05-21-2012, 01:33 PM
Speed Direct
Premium Supporting Vendor
Speed Direct's Avatar
Are you talking the fitting attaching at the rack itself? That should be an 18mm x 1.5 o-ring (bump tube) style.
Old 05-21-2012, 03:15 PM
spazegun2213
Thats the one!! thanks a ton!
To Power steering question
Quick Reply: Power steering question
