Front Tow Hook Dimensions?
Old 05-26-2012, 01:59 PM
jd_black_00
jd_black_00's Avatar
2016 C5 of the Year Finalist
St. Jude Donor '12, '14
Default Front Tow Hook Dimensions?
Hi,
I was looking to build myself a front-mounted tow hook, but I'm not sure how long/wide it needs to be. Does anyone have dimensions that they used to make one? Also, what grade/alloy did you use?
Thanks!
Old 06-07-2012, 01:29 PM
waffle1971
waffle1971's Avatar
I am curious about this, as well. Also - where is the best spot to mount it?
Old 06-08-2012, 07:32 AM
isnider
isnider's Avatar
I just ordered the OEM factory hook and bracket for the C6 Z06/ZR1, I'll take a pic and measure it when it gets here next week.
Ian
Old 06-08-2012, 09:53 AM
Z07coupe
Z07coupe's Avatar
I remember looking up the various regs on tow hooks when I was designing my C 4 front tow hooks. My tow hooks have an oval hole measuring 2" x 2.5". This oval hole (eyelet) is more than adequate for a hook or strap to be attached.
I still Have ready: C 4 front tow hooks, C 4 front cable guide (a different type of tow hook) and fire extinguisher mounts for C 4-5-6.
Old 06-08-2012, 12:31 PM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
How much for a C4 front tow hook?
Old 06-08-2012, 12:59 PM
TLGunman
TLGunman's Avatar
Certain sanctioning bodies have different dimensions, matl reqts. too, so you may need to check those if it matters.
Old 06-10-2012, 09:43 AM
Z07coupe
Z07coupe's Avatar
PMs sent.
Old 06-18-2012, 03:44 PM
isnider
isnider's Avatar
Here is a pic of the factory C6 tow hook for european export
GM part number 10438557
It is roughly 7" long and the eye has an inside diameter of 1-5/8"
It costs around $30 from forum vendors
Old 06-19-2012, 11:02 AM
trapp
trapp's Avatar
Where does this insert? Is there any modification needed...I have a 2011 GS will it work for my car?
Old 06-19-2012, 01:50 PM
c4cruiser
c4cruiser's Avatar
I would like some info about the C4 hook and cable guide. Pics too if you have them. I have an 87. PM the info if you have a chance. Thanks!!
Old 06-19-2012, 06:52 PM
isnider
isnider's Avatar
There is a factory OEM bracket that has to be welded to the front cross member. Yes you have to remove the bumper but this is the only GM engineered solution and you don't have to cut any holes in the bumper or grill and the hook screws in and out.
The other aftermarket ones look like kinda of an after thought to me and I question their strength and practical use. The GM hook is forged steel and looks 4x the thickness of the popular aftermarket ones. The reciever bracket welded to the front cross member is steel for all C6's except the Z06/ZR1 that are aluminum billet for the aluminum frame.
Ian
To Front Tow Hook Dimensions?
Quick Reply: Front Tow Hook Dimensions?
