Breaking in a new crate motor for racing
Old 06-08-2012, 12:21 AM
MJM
MJM's Avatar
Default Breaking in a new crate motor for racing
Blew my engine at last race. Have a new LS6 crate motor being installed but won't have much time for break in.
What is some good advice for doing the break in properly so I can enjoy a relatively long racing life from it?
Thanks,
Matt
Old 06-08-2012, 12:22 AM
RX-Ben
RX-Ben's Avatar
Abuse it from the get go.
Old 06-08-2012, 01:03 AM
Dirty Howie
Dirty Howie's Avatar
Sounds stupid but I agree 100%
Just make sure its fully warmed up. And might want to change the oil after a session or 2.
DH
Old 06-08-2012, 01:06 AM
froggy47
froggy47's Avatar
Since it's a track car, it's hard to put miles on b4 you run it.
A new street motor is going to be tight & run hot, no way around it.
I would self impose some lap limits, watch the gauges closely, at the sign of any heat issues do cool down or pull to pits & drive around periphal roads EASY.
Maybe get 100-200 miles on it, dump oil & filter & good to go.
I wouldn't run it over 5500 if it were mine. Maybe once a lap.
Maybe dino oil, but I would try to get advice from someone who has done it. Maybe not.
Let us know.
Old 06-08-2012, 01:28 AM
jimtway
jimtway's Avatar
I let mine idle for about 30 minutes, followed with 2000 rpm for 30 minutes, then 2 sessions at no more than 5500 rpm. Changed the oil and let it rip.
Old 06-08-2012, 01:43 AM
Sidney004
Sidney004's Avatar
Same here.
http://www.mototuneusa.com/break_in_secrets.htm
Old 06-08-2012, 04:16 AM
Olitho
Olitho's Avatar
...says that rat bastard that is getting 408 HP out of a crate engine.
Old 06-08-2012, 07:58 PM
Timz06
Timz06's Avatar
I would try to put a couple hundred discreet miles on the backroads before I hit the track.
Old 06-08-2012, 08:36 PM
CHJ In Virginia
CHJ In Virginia's Avatar
To the OP == Where did you find a GM LS6 crate motor ?? They have been non existant for about a year or so ??
Old 06-08-2012, 09:56 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
Get to an HPDE weekend soon so you can drive it as you need for good break in.
Old 06-08-2012, 10:14 PM
trackboss
trackboss's Avatar
Go break it in on a rw dyno for a half hour. After than run the **** out of it.
Old 06-08-2012, 11:05 PM
CeeFiveZee
CeeFiveZee's Avatar
Absolutely. Dyno time is cheap compared to the cost of a new engine. I was allowed to run my racecar on the dyno and run it through the gears for 30 mins for $100.
Old 06-09-2012, 11:28 AM
travisnd
travisnd's Avatar
If it's a GM crate motor then it should already be run-in on the dyno and ready to go. The break-in period in a new street car is really for the transmission and rear end to develop good wear patterns for long service life.
If it's a newly built motor with no run time, then I'd do the dyno thing for 30 minutes, change the oil and go.
Old 06-09-2012, 04:47 PM
rustyguns
rustyguns's Avatar
Old 06-09-2012, 05:17 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
If you cannot run it on the street. Gm probably runs them for 2-3 minutes or even less to see the power and all is OK. Put a fan in front if you are idling it. After the first session I would run it up to redline few times. Many happy miles ahead!
Old 06-09-2012, 05:58 PM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
Yup..people get so nuts about break in time for new cars and such. Over done. Only thing I put street miles on a bit was a new diff and clutch. Motor, just pound it.
To Breaking in a new crate motor for racing
Quick Reply: Breaking in a new crate motor for racing
